1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86
To: [email protected]
Date: Mon, 25 Feb 2013 10:30:28 -0600
Hi Dirk,
On 2013-02-25 Dirk Zimoch wrote:
> I had to comment out cap5 for several cross linux architectures. (which
> I build as "HOST" architecture in order to have caget and friends.)
In 3.14.12.3 the catools products are built on all OSs except for vxWorks,
RTEMS and iOS (because those OSs don't support stand-alone executables).  You
fixed the wrong thing, and you're probably compiling more stuff than you need
to on those cross-build architectures.
> Also
> if the compiler you use to build EPICS is not the one that was used to
> build perl you get into trouble.
That's the main problem on Windows, which is why cap5 can't usually be built
there — mixing the Perl and EPICS build systems is fragile.  In 3.14.12.3
Windows doesn't try to run podchecker any more either.
> Do we really need cap5 in EPICS base? I would like to see it in a
> separate module.
Yes, I want to be able to use it in self-tests, so we can write regression
tests for record types and soft device support.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Dirk Zimoch
Prev: Compiling MEDM and Striptool on Ubuntu 1204 Kohler
Next: Re: Compiling MEDM and Striptool on Ubuntu 1204 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
Next: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
