1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Compiling MEDM and Striptool on Ubuntu 1204
To: tech-talk <[email protected]>
Date: Mon, 25 Feb 2013 18:18:46 +0200
Just in case anyone is having problems compiling MEDM on Ubuntu1204, here are some tips:
MEDM compile expects some library files in /usr/lib
Ubuntu1204 puts these files in /usr/lib/i386-linux-gnu
so one needs the following symbolic links in /usr/lib, MEDM then compiles:
  ln -s /usr/lib/i386-linux-gnu/libXm.a /usr/lib/libXm.a
  ln -s /usr/lib/i386-linux-gnu/libXt.a /usr/lib/libXt.a
  ln -s /usr/lib/i386-linux-gnu/libXp.a /usr/lib/libXp.a
  ln -s /usr/lib/i386-linux-gnu/libXmu.a /usr/lib/libXmu.a
  ln -s /usr/lib/i386-linux-gnu/libX11.a /usr/lib/libX11.a
  ln -s /usr/lib/i386-linux-gnu/libXext.a /usr/lib/libXext.a
  ln -s /usr/lib/i386-linux-gnu/libXm.so /usr/lib/libXm.so
Remember to install the following package for the larger fonts used by MEDM to work on Ubuntu1204:
  apt-get install xfonts-100dpi
For StripTool you also need:
  ln -s /usr/lib/i386-linux-gnu/libXpm.a /usr/lib/libXpm.a
Cheers,
Ivan Kohler
iThemba LABS
Re: Compiling MEDM and Striptool on Ubuntu 1204 Andrew Johnson
Re: Compiling MEDM and Striptool on Ubuntu 1204 J. Lewis Muir
Re: Compiling MEDM and Striptool on Ubuntu 1204 Keith Thorne
Prev: Re: Problem when loading epics3.14.12.1 application tovxWorks5.5/MPC8572 Dirk Zimoch
Next: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem when loading epics3.14.12.1 application tovxWorks5.5/MPC8572 William F. Steele
Next: Re: Compiling MEDM and Striptool on Ubuntu 1204 Andrew Johnson
