Hi Ivan,
On 2013-02-25 Kohler wrote:
> Just in case anyone is having problems compiling MEDM on Ubuntu1204,
> here are some tips:
> MEDM compile expects some library files in /usr/lib
Not actually true, you can adjust where the build looks for those files by
editing your extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86 file and
changing the X11_* and MOTIF_* settings. The default values do assume that's
where they are found, but you should *never* need to modify your OS like that
to get EPICS programs to build or run.
> Remember to install the following package for the larger fonts used by
> MEDM to work on Ubuntu1204:
> apt-get install xfonts-100dpi
That is true.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Compiling MEDM and Striptool on Ubuntu 1204 Kohler
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Re: Compiling MEDM and Striptool on Ubuntu 1204 J. Lewis Muir
<2013>
2025
2026
<2013>
2025
2026
