Hi:
Depending on what version of autosave you are using, you can work without any standalone autosave config files.
Instead, you add annotations to your database records:
record(type, "$(S):SomeRecord")
info(autosaveFields, "VAL LOW")
The granularity of autosave configuration files is thus just the database files:
One database per device? -> That database file also contains the autosave info.
When you create new *.db files, it is easy enough to add those info annotations right away.
If your application uses existing *.db files that you don't want to edit, note that you can load multiple definitions of the same record. You can load a second database file that contains the same record names, but only the missing info annotations:
In your IOC startup file you then add a command that auto-creates the request files from those database annotations:
makeAutosaveFileFromDbInfo("autocreated.req", "autosaveFields");
create_monitor_set("autocreated.req.req", 5)
-Kay
On Apr 11, 2013, at 19:43 , Emmanuel Mayssat wrote:
> I have several device running in a master IOC.
> I would like to use autosave.
> The issues is that I would like to break down my master IOC into smaller ones at will (for development purpose).
> I would like to use several req files and restore files for autosave.
> In other words, I would like to have one autosave configuration per device in the master IOC.
> Q: Is there a limitation to the number of files and instance of autosave in a single IOC?
> Regards,
> Emmauel
- RE: autosave limitation? Emmanuel Mayssat
- autosave limitation? Emmanuel Mayssat
CSS BOY - global widget properties modification Vítek Michal
<2013>
2025
2026
<2013>
2025
2026
