1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: autosave limitation?
To: "Kasemir, Kay" <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Apr 2013 15:03:12 -0700
> Depending on what version of autosave you are using, you can work without any standalone autosave config files.
> Instead, you add annotations to your database records:
> record(type, "$(S):SomeRecord")
> info(autosaveFields, "VAL LOW")
> In your IOC startup file you then add a command that auto-creates the request files from those database annotations:
> makeAutosaveFileFromDbInfo("autocreated.req", "autosaveFields");
> create_monitor_set("autocreated.req.req", 5)
Again, I want the flexibility to have 1 master IOC with 20 devices to be broken in several
(i.e. let's say I reconfigure the master IOC with 15 devices and 5 single-device IOCs that actively being developed)
This should of course be transparent from the EPICS client perspective
(i.e. restored values are the same)
I understand how to generate the req file (dbgrep * > file.req or more complicated as described above)
But what about restoring the PVs, i.e. what about the sav files?
There are 2 solutions:
1/ Have one req file per device  --> one sav file per device
2/ Have one req file per device -->  one sav file used for all IOCs
But
1/ Limits on number of sav files in autosave
2/ I anticipate issues as several processes try to write to the same file
is there a reason why autosave is limited to 8 files?
Can this limit be raise to say ... 1000?
Better yet, can this limit be removed?
I moved away from autosave some time ago due to that limit.
Is there anything that has the same functionality as autosave but would better fit my development methodology?
Emmanuel
Re: autosave limitation? Tim Mooney
autosave limitation? Emmanuel Mayssat
Re: autosave limitation? Kasemir, Kay
Prev: Re: EPICS UTC Time conversion Eric Norum
Next: RE: EPICS UTC Time conversion Kim, Kukhee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave limitation? Kasemir, Kay
Next: Re: autosave limitation? Tim Mooney
