1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: autosave limitation?
To: Tim Mooney <[email protected]>
Cc: emmanuel mayssat <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 17 Apr 2013 11:14:29 -0700
Can this value be increased in the source instead and be available in the next release (whenever that is)?
Applying a patch as simple as this requires
- create the patch
- modify the autosave installation script to apply patches
- document the change
- inform QA
- inform coworkers
when 6 months later, you have machine operations issue and you realize that
- a rogue IOC
- installed by an intern
- who did not read the documentation
- did a manual install and was unaware of the patch
- ... <insert worse case scenario here>... including downtime and hardware damage ;-)
Could you please increase the value of  MAXRESTOREFILES (or implement a chained list) in the next version of autosave?
Emmanuel
> There's no real reason autosave is limited to 8 files, other than that I
> didn't know anyone wanted more than that. I haven't tested large numbers
> of files, but you can edit save_restore.h and change
> #define MAXRESTOREFILES 8
> to whatever you want. The number of save files is already unlimited (you
> can make as many create_monitor_set() calls as you want.)
> Yes, the number of restore files could be made unlimited. That's what I
> meant to imply when I said that the list of restore file names could be
> implemented as a linked list. If someone wants 1000 files, then a linked
> list is probably called for. If 30 is enough, then
> #define MAXRESTOREFILES 30
> seems adequate. All we're doing is allocating an array of pointers.
> Tim
> Tim Mooney ([email protected]) (630)252-5417
> Software Services Group (www.aps.anl.gov)
> Advanced Photon Source, Argonne National Lab
Re: autosave limitation? Tim Mooney
RE: autosave limitation? Emmanuel Mayssat
Prev: Re: Linux USB serial questions Eric Norum
Next: Re: sscan/ saveData problem with RW permission, and not an NFS issue Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave limitation? Tim Mooney
Next: Re: autosave limitation? Tim Mooney
