On 05/10/13 03:25, Geon-Yeong Mun wrote:
> I tried to run the mrfioc2 EPICS module for the MRF's
> VME-EVG-230&VME-EVR-230(not VME-EVR-230RF).
FYI there is a known issue with the VME-EVR-230 (not RF) firmware
identifying itself as an VME-EVRRF-230. The 8th Front panel output
won't be configurable until this is fixed.
> When EVG generate the Event Code 125, then EVR print the error-message.
> recGblGetTimeStamp: epicsTimeGetEvent failed, TST{evr:1}Time-I.TSE = 125
The error means that timestamp 1Hz reset event #125 was received, but
the EVR did not record a valid reception timestamp. It is expected that
this will be shown 5 times per EVR when time stamping reception begins.
Since the log you sent does not show the message "Starting
timestamping", I don't think the EVG is sending the timestamp shift events.
Of course right now I can't think of why it should work... I'll try to
repeat this today to see if I made some mistake in the procedure.
Michael
- epicsTimeGetEvent failed Geon-Yeong Mun
Actual time in XY graph Himanshu Tyagi
RE: EDM Mark Rivers
<2013>
2025
2026
Re: Re: epicsTimeGetEvent failed Geon-Yeong Mun
<2013>
2025
2026
