1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: epicsTimeGetEvent failed
To: <[email protected]>
Cc: [email protected]
Date: Mon, 13 May 2013 14:52:34 +0900
Hello, Michael Davidsaver.
Actually, I had to modify your source. (CR/CSR access mode, Register access mode)
As a result, I was using an oscilloscope to check the signal coming from the output channel of the front panel of the EVR.
The signal was obtained from DBUS.
And, I tried to run the EVG&EVR as Event-Code.
So, I need a timestamp. when I operate the timestamp, then the following message comes.
recGblGetTimeStamp: epicsTimeGetEvent failed, TST{evr:1}Time-I.TSE = 125
I don’t see the message “Starting timestamping….”.
But, When EVG acted the 1PPS, then i was see the message.
0x46ac410 (cbHigh): Unhandled C++ exception resulted in call to terminate
Thread cbHigh (0x46ac410) suspended
Timestamping timeout
epicsThread: Unexpected C++ exception "epicsTime_localtime failed" with type "St11logic_error" in thread "Watch Dog Timer" at <UKN DATE>
0x450a010 (Watch Dog Timer): Unhandled C++ exception resulted in call to terminate
I think that this message EVG’s(not EVR).
Can you explain this message?
Best Regard.
Geon-Yeong.
vxWorks localtime_r fails? (was epicsTimeGetEvent failed) Michael Davidsaver
Prev: Re: SNC: evflags not available to escaped C Benjamin Franksen
Next: RE: CA subscription synchronisation shutdown problem michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsTimeGetEvent failed Michael Davidsaver
Next: vxWorks localtime_r fails? (was epicsTimeGetEvent failed) Michael Davidsaver
