Am Donnerstag, 9. Mai 2013, 21:20:00 schrieb Joe Sullivan:
> SNC evflags used to be made available to escaped C code via #define
> /* SNC Version 2.0.12: Wed Jun 16 13:13:56 2010: batch_scan_v3.i */
> /* Event flags */
> #define updateTime 1
> #define modeChange 2
> #define positioner1Done 3
> #define positioner2Done 4
> #define positioner3Done 5
> Now the 'enums' are defined in-line in sequence code but not in
> escaped C functions where they become undefined variables.
> # line 2107 "../batch_scan_v3.st"
> seq_efSet(ssId, 3/*positioner1Done*/);
> Was this done on purpose?
It is always fascinating what uses people find for stuff once it exists...
I simply did not imagine that use case! The change was done simply to bring
event flags in line with how variables are treated (which you cannot directly
use in embedded C code for similar reasons).
Obviously that was flawed thinking on my part. Because for variables there is
pvIndex function, which unfortunately refuses to work with event flags. But
this is actually not a big problem, because you can just leave it off, see
below.
> What is the best way around this?
There is indeed a trick which works: you pass the event flag to your C
function as a value of type EV_ID (which is a synonym for 'unsigned' but that
need not concern you):
program event_flag_in_c_func
evflag x;
static void efSet_x(SS_ID ssId, EV_ID x)
seq_efSet(ssId, x);
/* call the C function from SNL code: */
ss myss {
state set_flag {
when () {
efSet_x(ssId, x);
} state check_flag
state check_flag {
when (delay(0.5)) {
printf("oops, timeout, didn't work\n");
} exit
when (efTest(x)) {
printf("cool, we came here, means it worked\n");
} exit
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- SNC: evflags not available to escaped C Joe Sullivan
Re: new archiver problem James F Ross
Re: Re: epicsTimeGetEvent failed Geon-Yeong Mun
<2013>
2025
2026
National Instruments PCI DAQmx Rafael Vescovi
<2013>
2025
2026
