Hello all, Thanks everyone for the help, I'll ask if any other problems come up.I've got an update on this problem. The issue wasn't the time stamps, though those may prove another issue once this is fixed. The problem I had was that the master_index file had reached its maximum size. I copied it over to make room for a new one, edited indexupdate.xml to include only 2012 and later index files, then ran: ArchiveIndexTool -v 1 indexupdate.xml master_index & This being the command that appears over and over in the ArchiveIndexTool.log file, but no master_index file appeared. The new master_index file was crated. I have yet to see if it will be continually updated as master_index is taking a while to build and I think the automatic update happens around 2 am, but I don't see why it wouldn't run as before. James On Fri, May 10, 2013 at 5:10 PM, James F Ross <[email protected]> wrote:
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
