1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epicsTimeGetEvent failed
To: <[email protected]>
Date: Fri, 10 May 2013 16:25:35 +0900
Hello all.
I tried to run the mrfioc2 EPICS module for the MRF's VME-EVG-230&VME-EVR-230(not VME-EVR-230RF).
Now, I tried to test In accordance with Section 6.1(EVG and EVR Checkout) of "EVR Usage Guide"
The settings related to the "Reset EVR heartbeat timeout counter", there is no problem.
But there is a problem in the settings related to the "Reset timestamp counter".
When EVG generate the Event Code 125, then EVR print the error-message.
recGblGetTimeStamp: epicsTimeGetEvent failed, TST{evr:1}Time-I.TSE = 125
I don’t know the meaning of this message. Please help me.
Thank you.
Best Regards.
GeonYeong
                            VxWorks System Boot
Copyright 1984-2011  Wind River Systems, Inc.
CPU: Motorola MVME6100-0173 - MPC 7457
Version: VxWorks 6.9
BSP version: 6.9/0
Creation date: Apr 16 2013, 16:55:52
Press any key to stop auto-boot...
1
auto-booting...
boot device          : geisc
unit number          : 0
processor number     : 0
host name            : gymun
file name            : /home/work/image/vxWorks
inet on ethernet (e) : 141.223.48.52:ffffff00
host inet (h)        : 141.223.48.51
gateway inet (g)     : 141.223.48.99
user (u)             : work
ftp password (pw)    : work
flags (f)            : 0x0
target name (tn)     : evg01
startup script (s)   : /home/work/st.vxWorks
Loading... 2348400
Starting at 0x100000...
Loading symbol table from gymun:/home/work/image/vxWorks.sym ...done
                VxWorks
Copyright 1984-2013  Wind River Systems, Inc.
    Runtime Name: VxWorks
Runtime Version: 6.9
     BSP version: 6.9/0
         Created: Apr 16 2013, 16:56:21
ED&R Policy Mode: Deployed
   WDB Comm Type: WDB_COMM_END
             WDB: Ready.
Executing startup script '/home/work/st.vxWorks'...
tyBackspaceSet(0177)
value = 127 = 0x7f
#ld < mrf.munch
ld < mrfTest.munch
value = 72204304 = 0x44dc010
# env setting
epicsEnvSet("ENGINEER","Geon-Yeong Mun")
value = 0 = 0x0
epicsEnvSet("LOCATION","testLab")
value = 0 = 0x0
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES","1000000")
value = 0 = 0x0
epicsEnvSet("EPICS_TS_NTP_INET","141.223.48.51")
value = 0 = 0x0
#dbLoadDatabase("dbd/mrf.dbd",0,0)
#mrf_registerRecordDeviceDriver(pdbbase)
dbLoadDatabase("dbd/mrfTest.dbd",0,0)
value = 0 = 0x0
mrfTest_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
# EVG(A24)
#mrmEvgSetupVME("EVG1",2,0x00050000,4,0xc0)
mrmEvgSetupVME("EVG1",2,0x00000000,4,0xc0)
##### Setting up MRF EVG in VME Slot 2 #####
Found Vendor: Can't register 's00000ystem' command eb2-- no command int
Board: erpreter ava454700e6ilable.
Revision: 00000000
FPGA version: 22000005
FPGAVersion 0x22000005
IRQ Level: 4
IRQ Vector: 192
csrCpuAddr : 0x8f0f0000
regCpuAddr : 0x90000000
value = 0 = 0x0
# EVR(A24)
#mrmEvrSetupVME("EVR1",5,0x00100000,3,0x26)
#mrmEvrSetupVME("EVR1",5,0x00200000,4,0x24)
#mrmEvrSetupVME("EVR1",5,0x08000000,3,0x26)
mrmEvrSetupVME("EVR1",5,0x00010000,3,0x26)
Setting up EVR in VME Slot 5
Found vendor: 00000eb2 board: 455246e6 rev.: 00000000
EVR check. EVR-230 'EVR1' slot 5
FPGA version... 0006
Found SFP Strangeness ffffffff
FWVersion 0x1VME64 2000006
Out FP:Found version 6
7 FPUNIV:4 RB:16 IFP:2
Using IRQ EVR FIFO t3ask start
:38
value = 0 = 0x0
# EVG db
dbLoadRecords("db/vme-evg230.db", "SYS=TST, D=evg:1, EVG=EVG1")
value = 0 = 0x0
# BNL specific timing sequence constructor
#dbLoadRecords("db/nsls2-inj-seqs.db","LN=LN-TS, BR=BR-TS, INJ=TST, EVG=evg:1, SEQ=SoftSeq:0")
# EVR
dbLoadRecords("db/evr-vmerf-230.db","SYS=TST, D=evr:1, EVR=EVR1")
value = 0 = 0x0
#dbLoadRecords("db/iocAdminRTEMS.db", "IOC=mrftest")
dbLoadRecords("db/iocAdminVxWorks.db", "IOC=mrftest")
value = 0 = 0x0
# Auto save/restore
#save_restoreDebug(2)
#dbLoadRecords("db/save_restoreStatus.db", "P=mrftest:")
#save_restoreSet_status_prefix("mrftest:")
#set_savefile_path("{mnt}/as","/save")
#set_requestfile_path("{mnt}/as","/req")
#set_savefile_path("/autosave","/save")
#set_requestfile_path("/autosave","/req")
#set_pass0_restoreFile("mrf_settings.sav")
#set_pass0_restoreFile("mrf_values.sav")
#set_pass1_restoreFile("mrf_values.sav")
#set_pass1_restoreFile("mrf_waveforms.sav")
iocInit()
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Apr 11 2013
Set EVR clock 124916000.000000
value = 0 = 0x0
#makeAutosaveFileFromDbInfo("/autosave/req/mrf_settings.req", "autosaveFields_pass0")
#makeAutosaveFileFromDbInfo("/autosave/req/mrf_values.req", "autosaveFields")
#makeAutosaveFileFromDbInfo("/autosave/req/mrf_waveforms.req", "autosaveFields_pass1")
#create_monitor_set("mrf_settings.req",10,"")
#create_monitor_set("mrf_values.req",10,"")
#create_monitor_set("mrf_waveforms.req",30,"")
Done executing startup script '/home/work/st.vxWorks'.
-> Set EVR clock 119000000.000000
-> generalTimeReport(2)
Backwards time errors prevented 4 times.
Current Time Providers:
    "EVR", priority = 50
        Current Time not available
    "NTP", priority = 100
        Current Time is $“.
    "OS Clock", priority = 999
        Current Time is $“.
Event Time Providers:
value = 0 = 0x0
Re: epicsTimeGetEvent failed Michael Davidsaver
Prev: Re: archiver tools macro support Jack
Next: Re: EDM Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM Zenon Szalata
Next: Re: epicsTimeGetEvent failed Michael Davidsaver
