Hi Andrew,
On 05/10/13 11:08, Andrew Johnson wrote:
Hi Zenon,
On 2013-05-10 Zenon Szalata wrote:
The hardware registers are read/write.
When the IOC starts, the register has some value previously set.
After IOC init, I issue a series of dbpf commands, one for each register.
These trigger processing a record that reads the register.
After the register is read, the read value is put into the output record
with NPP.
The record you showed was Soft Channel though, was this what you're calling an
an output record? I see that it does have a forward link.
Yes, it is a longout record, so I called it output.
These are Beckhoff bus terminal records which are a bit complicated to
read from and especially to write to. To have it work correctly, I need
to insert a 0.2 second delay between dbpf commands.
I decided to use NPP because the output record, although it is soft
channel, when processed will result in the value being written back to
the register, which should be harmless, but I wanted to avoid it,
because significantly more delay would be needed.
Unfortunately for most record types doing a dbPut() to the VAL field without
processing the record will *not* trigger a CA monitor for the field. If the
VAL field is PP(TRUE) the code in dbPut() assumes that puts to the field will
cause the record to be processed and that processing will trigger a monitor,
so it doesn't do one itself to avoid sending an unnecessary double update. In
your case though you're not processing the record, so EDM never gets sent an
update even though subsequent caget or dbpr commands do show the new value.
I started this thread after observing that EDM was singling out one
particular record and always the same one. Number of similar records
were handled the same way and their values made it to the Text
Controls. Also, relaunching the EDM was not enough to get the correct
value. Just this morning I discovered that restarting the EDM program
would get the correct value. I was strongly convinced and no longer am
that closing a screen (one of many control by an EDM program) resulted
in CA disconnect to all PVs referenced by that screen. I thought that
just putting the screen in question in a debug mode and then back in
execute, would also do CA disconnect/connect or at least the correct
values would be obtained. This was not happening. Well, I am still
confused by this whole thing.
If this is really the cause of my difficulty, I will think how to modify
the records such that the target output record gets the value and gets
processed and somehow writing back to the register will be suppressed.
I was trying to avoid the extra complication.
The SDIS link of the subsequent record might be useful here.
- Andrew
Thanks Andrew,
Zen
- EDM Zenon Szalata
- Re: EDM Andrew Johnson
- Re: EDM Zenon Szalata
Re: channel archiver questions James F Ross
new archiver problem James F Ross
<2013>
2025
2026
epicsTimeGetEvent failed Geon-Yeong Mun
<2013>
2025
2026
