Hi Zenon,
On 2013-05-10 Zenon Szalata wrote:
> The hardware registers are read/write.
> When the IOC starts, the register has some value previously set.
> After IOC init, I issue a series of dbpf commands, one for each register.
> These trigger processing a record that reads the register.
> After the register is read, the read value is put into the output record
> with NPP.
The record you showed was Soft Channel though, was this what you're calling an
an output record? I see that it does have a forward link.
> These are Beckhoff bus terminal records which are a bit complicated to
> read from and especially to write to. To have it work correctly, I need
> to insert a 0.2 second delay between dbpf commands.
> I decided to use NPP because the output record, although it is soft
> channel, when processed will result in the value being written back to
> the register, which should be harmless, but I wanted to avoid it,
> because significantly more delay would be needed.
Unfortunately for most record types doing a dbPut() to the VAL field without
processing the record will *not* trigger a CA monitor for the field. If the
VAL field is PP(TRUE) the code in dbPut() assumes that puts to the field will
cause the record to be processed and that processing will trigger a monitor,
so it doesn't do one itself to avoid sending an unnecessary double update. In
your case though you're not processing the record, so EDM never gets sent an
update even though subsequent caget or dbpr commands do show the new value.
> If this is really the cause of my difficulty, I will think how to modify
> the records such that the target output record gets the value and gets
> processed and somehow writing back to the register will be suppressed.
> I was trying to avoid the extra complication.
The SDIS link of the subsequent record might be useful here.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
- Re: EDM Zenon Szalata
- EDM Zenon Szalata
- Re: EDM Andrew Johnson
Re: Asyn-based TCP/VXI-11 interface to many devices Rod Nussbaumer
Re: channel archiver questions James F Ross
<2013>
2025
2026
<2013>
2025
2026
