1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn-based TCP/VXI-11 interface to many devices
To: epics Techtalk <[email protected]>
Date: Fri, 10 May 2013 10:51:46 -0700
Hi Eric.
Which protocol gets used will be partly a function of which PS's are ultimately chosen. So far I haven't used VXI-11 on devices that support it, as I haven't actually seen any particular advantage over a raw TCP stream. If I've missed something, I could be persuaded to switch.
What significance do you put on TCP low-level connection maintenance at the IOC level. I've always treated that as a black-box that applications shouldn't need to look into. StreamDevice seems to do a fair job of handling timeouts in my experience so far. I am still a bit skeptical about the reliability of reconnecting to broken connections, and this is also going to be the subject of some exploration. I have seen connections fail to re-connect in the past, and it's difficult assess whether the problem originates at the peer host, the OS, asyn,....
As you haven't noted any deficiencies, I assume that your interface to 55 supplies are working properly?
Thanks.
   ---   rod.
On 05/10/2013 10:14 AM, Eric Norum wrote:
We have 55 Caen A36xx supplies connected to a single Linux IOC process and 24 supplies to another.  Communication is over a raw TCP/IP stream using ASYN plus a small custom driver since there are some features of the command set that don't fit well with StreamDevice.  At some point I plan to try UDP/IP to see if that gives better performance.  My concern with TCP/IP is that error/timeout checking and retries happen at a level below where the IOC can easily keep track of what's happening.
Do you plan to use VXI-11, or a raw TCP/IP stream, or a Telnet (RFC-854, RFC-2217) stream to communicate with the devices?   ASYN has support for all three options.
On May 10, 2013, at 9:43 AM, Rod Nussbaumer<[email protected]>  wrote:
Hi all.
We are planning for installation of new beamlines requiring approximately 130 magnet power supplies. The proposed supplies (a few different manufacturers and models being considered) may be controlled using VXI-11/Telnet style interfaces, and using SCPI style commands. This implies the use of StreamDevice + Asyn interfaces in EPICS IOCs. My concern is about the scalability of ssyn with the large number of TCP connections to the power supplies. Each power supply will require an asyn IP port to be maintained. Until now, I have only configured asyn-based applications using 2 or 3 ports on a single IOC. This seems like a significant departure from what I consider a conventional system.
The IOC platform would probably be a VME hosted CPU running Linux, with an ethernet interface dedicated as a kind of VXI-11 fieldbus. It is possible, or likely, that control of the 130 supplies will be spread across 2 or 3 hardware IOC hosts.
Does anyone have any experience with this kind of configuration? Any problems to anticipate? Any problems that have known solutions? I am planning to try some kind of simulation using multiple physical hosts, possibly using multiple virtual hosts on each. Each host/virtual-host would simulate a power supply. Does this seem like a representative test?
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Asyn-based TCP/VXI-11 interface to many devices Rod Nussbaumer
Re: Asyn-based TCP/VXI-11 interface to many devices Eric Norum
Prev: channel archiver questions James F Ross
Next: Re: EDM Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn-based TCP/VXI-11 interface to many devices Eric Norum
Next: channel archiver questions James F Ross
