1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: [email protected]
Date: Mon, 24 Jun 2013 10:14:08 -0500
Hi Benjamin,
> your proposal tries to reify all the possible ways to compare two closures
> (listener code + environment) as data. Another approach, which I personally
> prefer, is to let users define their own matching criteria, i.e.
This is a C API, C doesn't have closures, and we're talking about changing a
minor part of a minor EPICS API.  We don't have anything comparable to your
matcher routine in the rest of Base and it would be confusing to introduce
this kind of thing here.  I only included all the possibilities I did because
there are valid use-cases to need both flag bits.  I don't want to change the
listener API like your proposal does; there is no reason to break user code
unnecessarily, and my version is completely backwards-compatible for existing
errlog listener source code.
> IMO, removing only the first matching list element is unsafe and should
> not be supported.
That behavior is explicitly tested for and relied on in the epicsErrlogTest.c
code.  The errlogRemoveListener() routine has behaved like that for a long
time and might actually be relied on in the wild for all we know...
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Problem in errlogRemoveListener Michael Abbott
Re: Problem in errlogRemoveListener Andrew Johnson
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: Re: Problem in errlogRemoveListener Benjamin Franksen
Next: PyEpics speed Jeremy Iken
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem in errlogRemoveListener Michael Abbott
