1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: registerRecordDevice... crashes IOC during startup
To: [email protected]
Date: Mon, 01 Jul 2013 10:22:19 +0200
On 01.07.2013 05:02, Andrew Johnson wrote:
Hi Ben,
On Jun 29, 2013, at 4:42 PM, Benjamin Franksen<[email protected]>  wrote:
Now I could conceive of some kind of optional way
to test your binary for completeness(which Dirk would not use), but for
VxWorks that would require that we know all of the symbols that your
specific VxWorks boot image provides since those are symbols which are
supposed to be undefined in your .munch file.
Hmm. I see. I wonder why loading a binary that references undefined symbols is
just a warning and not a fatal error, so the startup script would stop at this
point. Or, is there a way to make it one? (This is actually more a VxWorks
question, not much to do with EPICS).
I think it is one in later versions (5.5), or it can be made to be one.
Here is the code I use in my module loader:
        int fd, loaderror;
        fd = open(libname, O_RDONLY, 0);
        loaderror = errno;
        if (fd >= 0)
            errno = 0;
            libhandle = loadModule(fd, LOAD_GLOBAL_SYMBOLS);
            if (errno == S_symLib_SYMBOL_NOT_FOUND)
                libhandle = NULL;
            loaderror = errno;
            close (fd);
My loader first checks for dependencies (that have been found by my Makefile) and loads them first. Then it loads the code (above the code for vxWorks, I have code for Linux and Windows, too). Then it loads the dbd file and finally (for EPICS 3.14) it calls the *_registerRecordDeviceDriver function.
We do that for years and it works fine for 3.13 and 3.14.
OTOH, I could imagine doing just what you said: checking for all symbols to be
defined by (additionally) scanning the boot image for symbols. I think we have
the tools available, don't we? Do you think it would be possible to hack
something up and (optionally) add it to our build rules?
It shouldn't be too hard; read in all the symbols from the .nm file that was used to create the OS image (I think there is one, if not use the .sym file), then make sure that every undefined symbol in the application's .nm file was defined in the OS one. We have Perl code to do some of those kinds of things, so it's probably not that hard to write the rest.
My module Makefile does something like this to automatically create missing epicsExportAddress() calls when I compile 3.13 device support for 3.14. It also creates the necessary infrastructure for snl code and sub/genSub/aSub records.
(Unfortunately I cannot yet automatically create the wrapper functions needed for iocsh callable functions.)
That seems like it might be half-way to us creating a fully bootable image
file containing both the IOC application code and the VxWorks OS, but I
don't think that would be quite as easy as it might seem because getting
initialization right (C++ static initializers for our code) could be
tricky. Has anyone ever tried to do that?
Not me; but isn't that what we do (by default) for RTEMS?
No quite, we use the build rules from the RTEMS build system to create a bootable RTEMS image that includes the application. The steps for making a VxWorks image are likely to be rather different, although we might be able to pull in the Wind River rules if we understood them enough. However as I said before I don't know how easy is would be to get the VxWorks combination working; we have special initialization code included for RTEMS, some of which has to be a bit different when running with GeSys.
- Andrew
registerRecordDevice... crashes IOC during startup Benjamin Franksen
Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
Re: registerRecordDevice... crashes IOC during startup Benjamin Franksen
Prev: Re: registerRecordDevice... crashes IOC during startup Dirk Zimoch
Next: ChanneIRPC never connected Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
Next: Re: registerRecordDevice... crashes IOC during startup Dirk Zimoch
