1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvGet timeout in sequencer 2.1.12
To: <[email protected]>, Jeff Hill <[email protected]>
Date: Wed, 3 Jul 2013 01:22:41 +0200
Am Mittwoch, 19. Juni 2013, 18:10:32 schrieb Benjamin Franksen:
> On Wednesday, June 12, 2013 12:38:40 J. Lewis Muir wrote:
> > On 6/12/13 11:10 AM, Benjamin Franksen wrote:
> > > On Monday, June 10, 2013 17:22:12 Carl Lionberger wrote:
> > >> Looking at the code in seq_ca.c and seq_if.c, it seems that if a
> > >> synchronous pvGet ever fails to get a callback from channel access,
> > >> the "get completion timeout" message is set in the channel metadata
> > >> and all subsequent attempts to do pvGets on that channel will fail as
> > >> in the first
> > >> message.  The latter occurs because there is a get semaphore for each
> > >> channel that the callback is supposed to give.
> > >> My thought is that if the callback doesn't come the semaphore should
> > >> be released in the same code that sets the "get completion timeout"
> > >> message.
> > > I find it very hard to judge what the correct behaviour is, here.
> > I think I've run into Carl's problem before too.
> > Could you supply the CA callback with a sequence number that would
> > uniquely identify the callback as being for a particular pvGet?  This
> > way, you could ignore a callback if it arrives for a pvGet that has been
> > abandoned.
I just found that fixing this is more subtle than I expected.
The problem is this: in order to be able to associate incoming put and get
events (callbacks from CA) to where the request originated, I need two pieces
of information:
(a) the variable
(b) the state set (~= thread)
Both pieces are identified via pointers. So I had to introduce a data type for
requests (a struct) that contains just these two pointers. I pass a pointer to
such a struct to ca_array_get_callback resp. ca_array_put_callback, which when
they call the callback, pass the pointer as an argument.
This pointer MUST be valid until I receive the callback that belongs to the
request! Because if not, then the callback routine accesses invalid memory,
leading to crashes or worse.
That means I must never call free (actually freeListFree, but that's not
important here) before the callback arrives. But what if it never arrives?
Then we get a memory leak. Arrgh!
This leads me to the following
Channel Access Question
Does the CA client library guarantee that callbacks for ca_array_get_callback
and ca_array_put_callback are eventually called, no matter what, assuming I
just wait long enough?
Note that "no matter what" includes lost connections etc.
If I can rely on all put/get request callbacks to be called, eventually, then
I can solve the (original) problem by using the request pointer as my unique
identifier. I'll have to store the request pointers, (quasi-) statically
allocating memory for (number of state sets)x(number of assigned variables)
request pointers, but taht's no different from storing the same amount of
semaphores which I already do. And I simply forget about timed out requests,
assuming that my callback will eventually be called and the memory freed.
If I cannot rely on this, then I have to keep track of timed out requests
(probably chaining them in a list), so that at least the disconnect handler
can finally free them. (That assumes that I *can* rely on the connection
handler to be called, eventually.)
Another solution would be to avoid allocation of request structs by pressing
the information I need into an integer and casting that from/to the void
pointer. This means that on 32 bit systems I have to introduce upper limits
(2^16 ) for the number of variables and the number of state sets per program.
The limits themselves are not unreasonable, but I would rather try to avoid
such an ugly hack.
All this headache could easily be avoided if the CA client API offered a way
to cancel pending requests.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
pvGet timeout in sequencer 2.1.12 Carl Lionberger
Re: pvGet timeout in sequencer 2.1.12 J. Lewis Muir
Prev: caLab Pierrick Hanlet
Next: weird error Julio Calvo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
Next: Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
