1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: "'Brian McAllister'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 8 Jul 2013 23:51:58 +0000
Hi Brian,
I have reproduced the problem.
I created a simple TCP socket server that sends unsolicited messages every 1 second.  The format of the message is very similar to the ones your Omega device sends, just without the special character for degrees (\0370) that was giving me some trouble.
I created a StreamDevice protocol file based on yours, and a simple 1 record database.
As you observed it runs for a little while and then it hangs up with a deadlock.  Here is the output when I do epicsThreadShowAll 1.  It is OK for a little while, then we get the deadlock.
epics> epicsMutexShowAll 1
ellCount(&mutexList) 85 ellCount(&freeList) 0
epicsMutexId 0x8e6de00 source ../../asyn/asynDriver/asynManager.c line 1886
epicsMutexId 0x8e6f1f0 source ../../../src/libCom/osi/epicsMutex.cpp line 222
This should be relatively easy to track down now that we can reproduce it with a simple dummy server.
I'll look at it tomorrow.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Brian McAllister
Sent: Monday, July 08, 2013 4:36 PM
To: Mark Rivers
Cc: 'Dirk Zimoch'; '[email protected]'
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
>>> On 7/8/2013 at 19:59:17 -0000, Mark Rivers wrote:
  > I may try to reproduce the problem using a TCP server that emulates
  > your device.
  > How quickly is it sending the unsolicited messages?
Nominally every 5 seconds. The lower limit is 1 second, which in practice
seems to be 1-2 seconds.
- brian
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Next: multiple servers on the same (loopback) interface Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
