Hi Lewis,
This problem did get resolved.
There were 2 problems. Both have to do with the way that StreamDevice handles I/O Intr scanned records, which is by polling.
1) Brian had set the noProcessEos flag to 1 on his drvAsynIPPort driver, so it was not using the EOS interpose interface. Since his device does not send an EOS character this seemed a reasonable thing to do. But I found that the problem of hanging went away if noProcessEos was set to 0. I don't completely understand this yet, but the EOS interpose layer does add another level of buffering.
2) Even with noProcessEos=0 my tests showed that not all messages from the device were resulting in record processing, some messages were missed. This was basically an interplay of two things:
- The device does not send a terminator and does not have a fixed message size, so the only way to detect the end of a message is by a timeout.
- The default polling rate of StreamDevice for an I/O Intr scanned record is the timeout, which defaults to 1.0 second. However, the PollPeriod parameter can be used to set it to another value.
I found that if I set PollPeriod = 100 ms, and I set noProcessEos=0 then my simulation driver worked fine (i.e. the I/O Intr scanned record processed for each message) with message periods of 0.1, 0.2, 0.5, 1.0, and 2.0 seconds.
So there appears to be a solution to the problem.
-----Original Message-----
Sent: Monday, July 15, 2013 9:27 AM
To: Mark Rivers
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
On 7/8/13 6:51 PM, Mark Rivers wrote:
> This should be relatively easy to track down now that we can reproduce it with a simple dummy server.
> I'll look at it tomorrow.
> Mark
Hi, Mark.
I'm curious; did this ever get solved? No worries if not, but since I
was following the thread, I'm interested to know what the problem was.
Lewis
- RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
- Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Re: Looking for STRUCK SIS3302 device driver Michael Davidsaver
single IOC on Linux with two ports Hovanes Egiyan
<2013>
2025
2026
naming services Silver
<2013>
2025
2026
