1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice send/recevie bit array problem
To: tech-talk <[email protected]>
Date: Thu, 11 Jul 2013 16:18:06 +0800
hi,tech-talk members:
    I'm using asyn+streamdevice for centos6 to send&receive hex bit arrays between ioc and my asyn device.  but I get problems.
    first IOC need to send bit array to make connection with device, such as 0x03 0x00 0x00 0x13 0x0e 0xe0 0x00 0x00 0x00 0x05 0x00 0xc1 0x02 0x03 0x00 0xc2 0x02 0x02 0x00, if succeed, a same array would be recevied such as 0x03,0x00,0x00,0x13........  so, this command should be send only once in record init.  and recevied bits should saved in a waveform record.
1. how could the bits send only once in record init?
2. when test for receving messages from device, error messages printed, but using 'caget'command in another terminal, I can get the data in record. What does the error messages mean?
here is the protocl/record and error messages:
test.proto ####################################################
ReplyTimeout = 80000;
ReadTimeout = 1000;
tpkt = \x03\x00\x00\x13\x0e\xe0\x00\x00\x00\x05\x00\xc1\x02\x03\x00\xc2\x02\x02\x00;
array_in {
out "\${tpkt}";
in "%r";  }
waveform record ################################################
record (waveform, "$(user):test")
    field (DTYP, "stream")
    field (INP,  "@test.proto array_in L0")
    field (FTVL, "UCHAR")
    field (NELM, "200")
    field (PINI, "YES")
    field (SCAN, "5 second")
error messages printed ###########################################
2013/07/11 15:51:25.815 L0 rootHost:test: connection closed in read
2013/07/11 15:51:25.816 L0 rootHost:test: I/O error after reading 0 bytes: ""
2013/07/11 15:51:25.816 L0 rootHost:test: Protocol aborted
    second, another bits array should be sent to device to get data array,such as 0x03 0x00 0x00 0x2e 0x02 0xf0 0x80 0xa8 0x25 0x80 0x02 0x1f 0xfb 0x81 0x01 0x03 0x82 0x01 0x03 0x83 0x01 0x7f 0xa4 0x16 0x80 0x01 0x01 0x81 0x03 0x05 0xe8 0x00 0x82 0x0c 0x03 0xec 0x00 0x18 0x3f 0x0f 0xf6 0x10 0x03 0x01 0xf8 0x90, and a same hex bits array should recevied,but when i do this ,error messages printed. it seems that the bits array sent could not be recognize corrcetly.
3. how could I slove this problem?
here I use the same proto and record:
mms_request="\x03\x00\x00\x2e\x02\xe0\x80\xa8\x25\x80\x02\x1f\xfb\x81\x01\x03\x82\x01\x03\x83\x01\x7f\xa4\x16\x80\x01\x01\x81\x03\x05\xe8\x00\x82\x0c\x03\xec\x00\x18\x3f\x0f\xf6\x10\x03\x01\xf8\x90";
array_in {
out "\${mms_request}";
in "%r";  }
    field (NELM, "200")
    field (PINI, "YES")
error messages printed ############################################################################
2013/07/11 15:57:27.186 _main_ No converter registered for format '%�'
2013/07/11 15:57:27.186 _main_ test.proto line 5: in format string: "%\x80\x02\x1f�\x81\x01\x03\x82\x01\x03\x83\x01\x7f�\x16\x80\x01\x01\x81\x03\x05�\x00\x82\x0c\x03�\x00\x18?\x0f�\x10\x03\x01�\x90"
2013/07/11 15:57:27.186 _main_ test.proto line 9: in command 'out'
2013/07/11 15:57:27.186 _main_ test.proto line 8: in protocol 'array_in'
2013/07/11 15:57:27.186 _main_ while compiling protocol 'array_in' for 'rootHost:test'
2013/07/11 15:57:27.186 _main_ rootHost:test: Protocol parse error
2013/07/11 15:57:27.186 _main_ rootHost:test: Record initialization failed
2013/07/11 15:57:27.687 _main_ rootHost:test: Record not initialised correctly
Can anybody give me some hints? thanks a lot for your help.
Best regards
Tomas Zhang 2013-07-10
Re: StreamDevice send/recevie bit array problem Dirk Zimoch
Prev: RE: weird build Andrew C. Starritt
Next: sequencer release 2.1.13 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Another strange CA observation Benjamin Franksen
Next: Re: StreamDevice send/recevie bit array problem Dirk Zimoch
