Hi Andrew,
Thanks for the info. No this won't be a issue for me - it was more a curiosity that I stumbled across.
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Sunday, 7 July 2013 3:31 AM
> To: Andrew C. Starritt
> Cc: tech-talk
> Subject: Re:
> Hi Andrew,
> This is not an intentional feature, but according to Janet Anderson it
> is a side-effect of our inclusion of .. in the list of paths that we're
> configuring vpath for the .db target. Apparently the vpath gets applied
> to targets as well as sources by GNUMake, and it causes this to happen
> because we use vpath to avoid having to duplicate some of the build
> rules.
> I have asked Janet to look at how many rules would need to be added to
> remove .. from the vpath list and we'll probably make that change on
> the 3.15 branch, but I think it's probably too big a change to do in
> 3.14.
> Thanks for the report, is this going to be a significant issue for you
> at all?
> - Andrew
> Sent from my iPad
> On Jul 4, 2013, at 8:52 PM, "Andrew C. Starritt"
> <[email protected]> wrote:
> > Hi all,
> > I found some strange build behaviour (on both base-3.14.12.3 using 64
> bit CentOs 5.9
> > and base-3.14.9 using 32 bit CentOs 5.4). If there is a db directory
> in top's parent
> > directory that contains a file with the same name as I'm trying to
> install into
> > the top's db directory, then the install does not happen.
> > The following demonstrates this:
> > cd /tmp
> > mkdir -p above_top/top
> > cd above_top/top
> > makeBaseApp.pl -t ioc Weird
> > cd WeirdApp/Db/
> > vi Makefile # uncomment the DB += xxx.db line
> > touch xxx.db
> > cd ../.. # back to top
> > make
> > ls -l db # the xxx.db file installed as expected - so
> far so good.
> > make clean uninstall
> > # and the weirdness starts here:
> > mkdir ../db
> > touch ../db/xxx.db
> > make
> > ls -l # no db diretory in top, and no installed
> xxx.db file.
> > Is this an intended feature, and if so what is the rationale?
> > Regards
> Synchrotron
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
- [no subject] Andrew C. Starritt
- Re: Andrew Johnson
RE: multiple servers on the same (loopback) interface Hill, Jeff
StreamDevice send/recevie bit array problem zhangning
<2013>
2025
2026
Re: Andrew Johnson
Which version of Eclipse is required for CSS 3.2.x Xinyu.Wu
<2013>
2025
2026
