In this case since your driver knows what bits should not be modified it may be clearer to just use mask=0xffff so SHFT=0. Then the B0, B1, etc. in the mbboDirect record map directly to the bits in the register. Your driver just needs to not actually modify the reserved bits.
Sent: Wednesday, July 17, 2013 2:23 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Subject: Re: mbbxDirect SHFT field
Hi Mark,
thanks for your answer.
I was using this mask, because all 0-bits are marked as "reserved" in
the manual of our
motor driver. So I wanted to make sure they are not written...
Good to know how the shift is calculated...I should check my other
mbbo/mbbi records as well.
Florian
On 07/16/2013 06:16 PM, Mark Rivers wrote:
> Hi Florian,
> If you look at the asyn/devEpics/devAsynUInt32Sigital.c device support you will see that for mbbi, mbbo, mbbiDirect and mbboDirect records the SHFT field is computed by the computeShift function in the record initialization function.
> This is the computeShift function:
> static int computeShift(epicsUInt32 mask)
> epicsUInt32 bit=1;
> int i;
> for(i=0; i<32; i++, bit <<= 1 ) {
> if(mask&bit) break;
> return i;
> So it sets SHFT to the first non-zero bit in the mask.
> You have set the mask to 0x1f3c, which is 0001 1111 0011 1100 in binary. The first non-zero bit is bit 2 (starting from 0) so SHFT is set to 2.
> So I think you need to use B0 and B1 for your switches, because the mask says that the mbboDirect value starts at bit 2, not bit 0 in the hardware register.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Florian Feldbauer
> Sent: Tuesday, July 16, 2013 10:15 AM
> To: EPICS Tech Talk
> Subject: mbbxDirect SHFT field
> Hey all,
> for the settings of the stop switch mode of a motor driver, we are
> using, a 16 bit code is used.
> Bit 2 and Bit 3 are coding the polarity of the "left" and "right" stop
> switch, respectively.
> I'm currently using bo records for each bit and one mbboDirect record to
> send all 16 bits at once to the device. As device support the
> asynUInt32Digital interface is used with a custom asynPortDriver:
> record( mbboDirect, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE" ) {
> field( DTYP, "asynUInt32Digital" )
> field( OUT, "@asynMask($(BUS),14,0x1f3c,1)TMCM142_SAP_U" )
> record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:LEFTSWITCHPOLARITY" ) {
> field( OUT, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B2 NPP" )
> field( ONAM, "active high" )
> field( ZNAM, "active low" )
> record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY" ) {
> field( OUT, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B3 NPP" )
> When I now set "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY"
> to one,
> PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.VAL is 8.
> So far so good.
> But the value in asynPortDriver::writeUInt32Digital is 0x20.
> Having a closer look to the mbboDirect record shows that SHFT is 2.
> Setting it to 0 inside the db-file has no effect.
> Any idea why it is set to 2? How can I change this behavior?
> The same problem occurs for the mbbiDirect record used to read back the
> settings.
> Best regards,
> Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 45 |
| D-55128 Mainz |
| Office: 01/102 |
| Phone: (+49)6131 / 39-27373 |
- mbbxDirect SHFT field Florian Feldbauer
- RE: mbbxDirect SHFT field Mark Rivers
- Re: mbbxDirect SHFT field Florian Feldbauer
Re: EPICS fsmRecord question Jiro Fujita
RE: Canberra AIM MCA 556B Mark Rivers
<2013>
2025
2026
Job Opening: Control System Software Engineer Position at SNS/ORNL Kasemir, Kay
<2013>
2025
2026
