1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record & PC6K: program upload fails
Date: Thu, 18 Jul 2013 15:03:59 -0400
While we're talking about the PC6K driver… has anyone started work to port it to one based on asynPortDriver? (ie. a motor model 3 driver)? We're heavily invested in the Parker controller here at the SNS and I was planning to update the driver to an asynPortDriver version.
Cheers,
Matt
On Jul 18, 2013, at 2:41 PM, Mark Rivers <[email protected]> wrote:
> Hi Martin,
> I don't know about the intended behavior, since I did not write the driver.  I am just saying what the actual behavior is. (Note that there is a comment in the driver code that says that I am the original author, but that is not true.  It is a remnant of someone's cut and paste from my Newport MM4000 driver on which this driver was based).
> I tend to agree with you that this seems like something that should be done before iocInit.
> PC6K_num_cards is set correctly after the PC6KConfig commands, and the required motor_state structures have been allocated.
> However, the motor_init() code is where the connection to the asyn driver occurs, and that does not happen until iocInit.
> If the code that initializes the connection to the hardware, like:
> 	/* Initialize communications channel */
> 	success_rtn = pasynOctetSyncIO->connect(cntrl->asyn_port,
>                                            cntrl->asyn_address, &cntrl->pasynUser, NULL);
> were moved from motor_init() into PC6KConfig() then you would be able to call PC6kUpLoad before iocInit().
> Mark
> -----Original Message-----
> From: Konrad, Martin [mailto:[email protected]]
> Sent: Thursday, July 18, 2013 1:13 PM
> To: Mark Rivers
> Cc: [email protected]
> Hi Mark,
>> So your PC6KUpLoad command must not be given before iocInit, it must be after iocInit.
> But would mean we reprogram the controller while the IOC is running and
> record processing is in full progress, doesn't it? That sounds quite
> dangerous to me. I was expecting it to program the controller before
> record processing starts. Can you please confirm that running it after
> iocInit really is the intended behavior?
> Martin
motor record & PC6K: program upload fails Konrad, Martin
Re: motor record & PC6K: program upload fails Konrad, Martin
RE: motor record & PC6K: program upload fails Mark Rivers
Prev: RE: motor record & PC6K: program upload fails Mark Rivers
Next: RE: Custom file saving plugin in AreaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RDB archiver disk space Jiro Fujita
