1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Convertion for asynFloat64
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 22 Nov 2013 11:16:01 -0600
Hi Lewis,
On 11/22/2013 10:53 AM, J. Lewis Muir wrote:
EPICS Base developers, it would be great if a write to the calcout VAL
field did trigger record processing.  But maybe there's a reason why it
doesn't?
I didn't design that record type, but why would you want to be able to write a value to a field when that value is normally going to be immediately overwritten when the record processes? Note that the pp(TRUE) setting only applies when doing a put through CA, a database link can directly control whether processing happens or not.
In this particular case you're getting clever with the record so I do understand the request, but the ability to access the VAL field from a Calc expression is a lot newer than the calcout record. Note also that in an OCAL expression, VAL actually returns the last value from the OVAL field, not the VAL field, so setting OCAL to "1000 * VAL" would not do the scaling of the VAL field that Benoit wants it to do.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Convertion for asynFloat64 J. Lewis Muir
Convertion for asynFloat64 Benoit
Re: Convertion for asynFloat64 Benoit
Prev: Re: Convertion for asynFloat64 J. Lewis Muir
Next: Re: Convertion for asynFloat64 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
