1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Convertion for asynFloat64
Cc: [email protected]
Date: Fri, 22 Nov 2013 11:39:15 -0600
On 11/22/13 11:16 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 11/22/2013 10:53 AM, J. Lewis Muir wrote:
>> EPICS Base developers, it would be great if a write to the calcout
>> VAL field did trigger record processing.  But maybe there's a reason
>> why it doesn't?
> I didn't design that record type, but why would you want to be able
> to write a value to a field when that value is normally going to be
> immediately overwritten when the record processes?
Hi, Andrew.
My only reason is just from a PV "API" standpoint.  Lots of people leave
off the ".VAL" suffix from the PV name, so in this case, they wouldn't
be able to do that unless the VAL field was pp(TRUE).
> Note that the pp(TRUE) setting only applies when doing a put through
> CA, a database link can directly control whether processing happens or
> not.
Interesting.  Thanks for pointing that out; I didn't know that.
> In this particular case you're getting clever with the record so I do
> understand the request, but the ability to access the VAL field from a
> Calc expression is a lot newer than the calcout record. Note also that
> in an OCAL expression, VAL actually returns the last value from the
> OVAL field, not the VAL field, so setting OCAL to "1000 * VAL" would
> not do the scaling of the VAL field that Benoit wants it to do.
Right, that's what I said when I wrote, "So maybe you could write to
that [the OVAL field], and use the OCAL expression and set DOPT to 'Use
OCAL' and get the behavior you want by writing to OVAL instead of VAL
(albeit confusing)?"
Lewis
Re: Convertion for asynFloat64 Benoit
Re: Convertion for asynFloat64 J. Lewis Muir
Re: Convertion for asynFloat64 Andrew Johnson
Prev: Re: Convertion for asynFloat64 Andrew Johnson
Next: RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Convertion for asynFloat64 Benoit
