1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Breakpoint tables: Raw value must be integer?!?
To: "Allison, Stephanie" <[email protected]>, "'Emmanuel Mayssat'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Nov 2013 14:15:49 +0000
I've taken the cheap way out -- instead of using Ampere for my current-to-field records, I use milliAmp integer values.
So instead of a 'sub' or 'aSub', I have to deal with one 'ai' and one trivial 'calc' record.
It's marginally simpler this way.
Cheers        -Mathias
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Allison, Stephanie
Sent: Friday, November 22, 2013 8:08 PM
To: 'Emmanuel Mayssat'; [email protected]
Hi Emmanuel,
> Is RVAL supposed to be an integer?
Yes.
> How can fix my current example?
I'm sure other people have a better solution but I use a subroutine record.  The logic looks something like this (I snipped code that you don't care about so maybe it doesn't compile):
RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Prev: RE: Error database DTYP Antonio Borondo
Next: RE: EpicsSharp issues Christopher J. Pendleton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Next: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
