1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Breakpoint tables: Raw value must be integer?!?
To: "Steiner, Mathias" <[email protected]>, "Allison, Stephanie" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Nov 2013 11:05:13 -0800
Breakpoint tables should be considered a basic feature of any control system, including EPICS.
I would like to make a petition to have the breakpoint table implementation reviewed.
My suggestions:
1/ RVAL in should be double (at least for ai/ao and maybe for all records)
2/ no check on monotonicity in X and Y.
    * Just properly document side effects in manual.  (Happy to take care of that!)
    * Whoever create the table and associated records should know what she/he is doing
Comments?
PS: Bob, I wouldn't mind contributing to the documentation.
Except most of the documentation is formatted as PDF documents or read-only html pages.
Emmanuel
> From: [email protected]
> To: [email protected]; [email protected]; [email protected]
> Date: Mon, 25 Nov 2013 14:15:49 +0000
> I've taken the cheap way out -- instead of using Ampere for my current-to-field records, I use milliAmp integer values.
> So instead of a 'sub' or 'aSub', I have to deal with one 'ai' and one trivial 'calc' record.
> It's marginally simpler this way.
> Cheers -Mathias
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Allison, Stephanie
> Sent: Friday, November 22, 2013 8:08 PM
> To: 'Emmanuel Mayssat'; [email protected]
> Hi Emmanuel,
> > Is RVAL supposed to be an integer?
> Yes.
> > How can fix my current example?
> I'm sure other people have a better solution but I use a subroutine record. The logic looks something like this (I snipped code that you don't care about so maybe it doesn't compile):
Re: Breakpoint tables: Raw value must be integer?!? Andrew Johnson
Re: Breakpoint tables: Raw value must be integer?!? Benjamin Franksen
Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
RE: Breakpoint tables: Raw value must be integer?!? Steiner, Mathias
Prev: RE: EpicsSharp issues Christopher J. Pendleton
Next: RE: EpicsSharp issues Christopher J. Pendleton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Breakpoint tables: Raw value must be integer?!? Steiner, Mathias
Next: Re: Breakpoint tables: Raw value must be integer?!? Andrew Johnson
