1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Breakpoint tables: Raw value must be integer?!?
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Mon, 25 Nov 2013 15:33:37 -0600
Hi Emmanuel,
On 11/25/2013 01:05 PM, Emmanuel Mayssat wrote:
Breakpoint tables should be considered a basic feature of any control
system, including EPICS.
I would like to make a petition to have the breakpoint table
implementation reviewed.
I think you're conflating two issues which are related but not identical. I'm not rejecting your concerns, but the solutions are not necessarily what you suggest they should be...
My suggestions:
1/ RVAL in should be double (at least for ai/ao and maybe for all records)
The ai & ao records were designed for interfacing to individual ADC and DAC devices, which even nowadays still present/accept data as some kind of an integer, hence the choice of a DBF_ULONG for RVAL still makes the most sense. Changing the type of the RVAL fields might require changing and would certainly need testing of a large number of device support routines at almost every EPICS site; I can't imagine fixing all the issues that would probably arise even just here at the APS, let alone at all the other sites.
Individual ai & ao device support may choose to provide or consume a double value (when interfacing to devices over GPIB say) in which case I believe the original design assumption was that some of the features such as engineering units conversion will have been taken care of by the remote device; the device support therefore must provide any missing record features that need to be supported.
The breakpoint table code in Base is actually a standard API and not built into the ao/ao records. This library code does not require that the raw value be an integer. Stephanie showed how it can be called from a subroutine record, and presumably the only reason why nobody has created a separate breakpoint table record is because it's not particularly hard to interface to it that way. If someone wanted to contribute such a record type to Base I would be happy to review and hopefully accept the result.
2/ no check on monotonicity in X and Y.
     * Just properly document side effects in manual.  (Happy to take
care of that!)
     * Whoever create the table and associated records should know what
she/he is doing
The monotonicity check is not implemented in the dbdExpand program that comes with 3.15, although the IOC still does the check (which can be disabled before loading the table as previously explained). I added this check back in 2006 (Base 3.14.9) while cleaning up the breakpoint library code, which was somewhat buggy at the time. I will admit that I probably should have added the -b flag to dbExpand at the same time, although it's easy enough to load a table into an IOC from its own DBD file which avoids having to use add that flag.
I will remove the monotonic checks if there is enough demand for them to go, but I do think that requiring engineers to explicitly disable them is safer and not that inconvenient.
PS: Bob, I wouldn't mind contributing to the documentation.
Except most of the documentation is formatted as PDF documents or
read-only html pages.
Bob is not in charge of that, I am, and there are ways you can contribute to the documentation:
* The Record Reference Manuel and various HowTo documents are currently on a Wiki at http://wiki-ext.aps.anl.gov/epics/index.php/Main_Page for which I will be happy to create you an account on request.
* Thanks to the late James Rowland, the Application Developers Guide is a multi-file LaTeX document, the source code for which has its own Bazaar project at https://launchpad.net/epics-appdev
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
RE: Breakpoint tables: Raw value must be integer?!? Steiner, Mathias
Prev: RE: EpicsSharp issues Christopher J. Pendleton
Next: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
