Peter,
Here's a patch that does not involve epicsStrDup or free:
corvette:motor/motorApp/MclennanSrc>svn diff
Index: drvPM304.cc
--- drvPM304.cc (revision 16975)
+++ drvPM304.cc (working copy)
@@ -356,6 +356,7 @@
char *p, *tok_save;
char response[BUFF_SIZE];
+ char temp[BUFF_SIZE];
struct PM304controller *cntrl;
size_t nwrite, nread;
int eomReason;
@@ -372,7 +373,8 @@
/* Device support can send us multiple commands separated with ';'
* characters. The PM304 cannot handle more than 1 command on a line
* so send them separately */
- for (p = epicsStrtok_r((char *) com, ";", &tok_save);
+ strcpy(temp, com);
+ for (p = epicsStrtok_r(temp, ";", &tok_save);
((p != NULL) && (strlen(p) != 0));
p = epicsStrtok_r(NULL, ";", &tok_save)) {
Debug(2, "send_mess: sending message to card %d, message=%s\n", card, p);
@@ -487,7 +489,8 @@
- for (p = epicsStrtok_r((char *) out, ";", &tok_save);
+ strcpy(temp, out);
Debug(2, "send_recv_mess: sending message to card %d, message=%s\n", card, p);
Please let me know if it fixes the problem, and if so I will commit it to Subversion.
Sent: Monday, December 16, 2013 3:51 PM
To: Mark Rivers
Cc: Torsten Bögershausen; Peter Linardakis; [email protected]; [email protected]
Subject: Re: Mclennan PM600 motor controller
Hello Mark,
I was able to recreate a problem (I presume it is "the" problem) that is
along the same line
that Torsten points to. More specifically, motor_init() in drvPM304.cc
makes this call when
it tests for the presence of the device,
> send_recv_mess(card_index, "1OA;", buff);
send_recv_mess() then calls epicsStrtok_r() with a pointer to the above
"1OA;" string. This call to
epicsStrtok_r() is, I believe, what is causing the crash Peter is
experiencing.
I suggest that both Torsten's patch to send_mess() and the following
patch to send_recv_mess()
are needed;
> Index: drvPM304.cc
> --- drvPM304.cc (revision 16681)
> @@ -484,10 +484,12 @@
> cntrl = (struct PM304controller *) motor_state[card]->DevicePrivate;
> + for (p = epicsStrtok_r((char *) temp, ";", &tok_save);
Hope this helps,
Ron
On 12/16/2013 8:04 AM, Mark Rivers wrote:
> Peter,
> I suspect Torsten has found the problem. "com" was declared "const char *", but it is being cast to "char *" when passed to epicsStrtok_r, which modifies the string. Some compilers put const data into memory blocks that are read-only, and this could cause your crash. I have definitely seen this with the Visual Studio compilers, (incorrect) code that ran OK on Linux would crash on Windows.
> Mark
> From: Torsten Bögershausen [[email protected]]
> Sent: Monday, December 16, 2013 2:51 AM
> To: Peter Linardakis; Mark Rivers; [email protected]; [email protected]
> Peter, does the following help:
> diff --git a/motorApp/MclennanSrc/drvPM304.cc b/motorApp/MclennanSrc/drvPM304.cc
> index e703082..3b15757 100644
> --- a/motorApp/MclennanSrc/drvPM304.cc
> +++ b/motorApp/MclennanSrc/drvPM304.cc
> @@ -352,8 +352,9 @@ STATIC int set_status(int card, int signal)
> /* ring buffer */
> /* send_mess() */
> -STATIC RTN_STATUS send_mess(int card, const char *com, char *name)
> +STATIC RTN_STATUS send_mess(int card, const char *com0, char *name)
> + char *com = NULL;
> char *p, *tok_save;
> @@ -367,12 +368,13 @@ STATIC RTN_STATUS send_mess(int card, const char *com, char *name)
> return(ERROR);
> + com = strdup(com0);
> + for (p = epicsStrtok_r(com, ";", &tok_save);
> @@ -381,6 +383,7 @@ STATIC RTN_STATUS send_mess(int card, const char *com, char *name)
> Debug(2, "send_mess: card %d, response=%s\n", card, response);
> + free(com);
> return(OK);
> On 12/13/13 3:54 AM, Peter Linardakis wrote:
>> Hi Mark
>> By including asynSetTraceMask("test-se1-1",0,255) in st.cmd, between boot and seg fault we get:
>> 2013/12/13 01:56:21.420 test-se1-1 asynManager::queueLockPort locking port
>> 2013/12/13 01:56:21.423 test-se1-1 asynManager::queueLockPort created queueLockPortPvt=0x289718
>> 2013/12/13 01:56:21.426 test-se1-1 asynManager::queueLockPort created queueLockPortPvt=0x289718, event=0x28ee98, mutex=0x28ef10
>> 2013/12/13 01:56:21.428 test-se1-1 asynManager::queueLockPort taking mutex 0x28ef10
>> 2013/12/13 01:56:21.430 test-se1-1 asynManager::queueLockPort queueing request
>> 2013/12/13 01:56:21.431 test-se1-1 addr -1 queueRequest priority 0 not lockHolder
>> 2013/12/13 01:56:21.432 asynManager::portThread port=test-se1-1 callback
>> 2013/12/13 01:56:21.434 test-se1-1 asynManager::queueLockPortCallback signaling begin event
>> 2013/12/13 01:56:21.435 test-se1-1 asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
>> 2013/12/13 01:56:21.436 test-se1-1 asynManager::queueLockPort waiting for event
>> 2013/12/13 01:56:21.437 test-se1-1 asynManager::queueLockPort got event from callback
>> 2013/12/13 01:56:21.438 test-se1-1 flush
>> 2013/12/13 01:56:21.439 172.16.0.108:5300 flush
>> 2013/12/13 01:56:21.440 asynOctetSyncIO flush
>> 2013/12/13 01:56:21.441 test-se1-1 queueUnlockPort
>> 2013/12/13 01:56:21.442 test-se1-1 asynManager::queueUnlockPort waiting for event
>> 2013/12/13 01:56:21.443 test-se1-1 queueUnlockPort unlock mutex 0x28ef10 complete.
>> 2013/12/13 01:56:21.445 test-se1-1 asynManager::queueLockPort locking port
>> 2013/12/13 01:56:21.445 test-se1-1 asynManager::queueLockPort taking mutex 0x28ef10
>> 2013/12/13 01:56:21.446 test-se1-1 asynManager::queueLockPort queueing request
>> 2013/12/13 01:56:21.447 test-se1-1 addr -1 queueRequest priority 0 not lockHolder
>> 2013/12/13 01:56:21.448 asynManager::portThread port=test-se1-1 callback
>> 2013/12/13 01:56:21.449 test-se1-1 asynManager::queueLockPortCallback signaling begin event
>> 2013/12/13 01:56:21.450 test-se1-1 asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
>> 2013/12/13 01:56:21.451 test-se1-1 asynManager::queueLockPort waiting for event
>> 2013/12/13 01:56:21.452 test-se1-1 asynManager::queueLockPort got event from callback
>> 2013/12/13 01:56:21.453 172.16.0.108:5300 read.
>> 2013/12/13 01:56:21.455 test-se1-1 queueUnlockPort
>> 2013/12/13 01:56:21.456 test-se1-1 asynManager::queueUnlockPort waiting for event
>> 2013/12/13 01:56:21.458 test-se1-1 queueUnlockPort unlock mutex 0x28ef10 complete.
>> and the gdb backtrace is:
>> Core was generated by `../../bin/linux-arm/pitest st.cmd'.
>> Program terminated with signal 11, Segmentation fault.
>> #0 0xb6d649d4 in epicsStrtok_r () from /opt/epics/base/lib/linux-arm/libCom.so
>> (gdb) backtrace
>> #1 0xb6eb4bb0 in send_recv_mess(int, char const*, char*) () from /opt/epics/modules/motorR6-8/lib/linux-arm/libMclennan.so
>> #2 0xb6eb5218 in motor_init() () from /opt/epics/modules/motorR6-8/lib/linux-arm/libMclennan.so
>> #3 0xb6eb49dc in PM304_init(void*) () from /opt/epics/modules/motorR6-8/lib/linux-arm/libMclennan.so
>> #4 0xb6de26d0 in dbInitDevSup () from /opt/epics/base/lib/linux-arm/libdbStaticIoc.so
>> #5 0xb6e7af8c in iocBuild () from /opt/epics/base/lib/linux-arm/libmiscIoc.so
>> #6 0xb6e7b52c in iocInit () from /opt/epics/base/lib/linux-arm/libmiscIoc.so
>> #7 0xb6d5ef78 in iocshBody () from /opt/epics/base/lib/linux-arm/libCom.so
>> #8 0x0000bcc4 in main ()
>> As far as the dbior command goes, I assume you meant commenting out the database that contains the motor record? If that's the case, the it seg faults before I get to a prompt, as it normally does and the backtrace is the same as above.
>> Regards
>> Peter
>> -----Original Message-----
>> From: Mark Rivers [mailto:[email protected]]
>> Sent: Friday, 13 December 2013 11:14 AM
>> To: Peter Linardakis; [email protected]; [email protected]
>> Subject: RE: Mclennan PM600 motor controller
>> Hi Peter,
>>> I had this nagging suspicion that I should indeed be basing my record
>>> on motor.db, but was confused from the motorR6-8 README file saying that serial devices needed asyn4-2. Live and learn I guess.
>> Your confusion is understandable. There are actually 2 layers in the motor software that use asyn.
>> 1) The interface between the motor driver and message based interfaces like RS-232, GPIB, and TCP/IP. The motor drivers always use asyn for this layer, even the old Model 1 drivers.
>> 2) The interface between motor record device support and the motor driver. Only Model 2 and Model 3 drivers use asyn in this layer.
>>> I changed the PM304Config(0, "test-se1-1", 1) line from PM304Config(1,
>>> "test-se1-1", 1), since I assumed from the "#C0 S0" syntax that if I only have one card, then it must be card 0.
>>> In this case, the IOC seg faults immediately after boot.
>> The correct command is card 0, as you did.
>> These are the command in my startup script:
>> # PM304 driver setup parameters:
>> # (1) maximum # of controllers,
>> # (2) motor task polling rate (min=1Hz, max=60Hz)
>> PM304Setup(1, 10)
>> # PM304 driver configuration parameters:
>> # (1) controller
>> # (2) asyn port
>> # (3) MAX axes
>> # Example:
>> # PM304Config(0, "serial1", 1)
>> PM304Config(0, "serial9", 1)
>> So now we need to figure out why it is segfaulting for you.
>> Your startup script has these lines:
>> drvAsynIPPortConfigure("test-se1-1", "172.16.0.108:5300") # Add these lines for asynTrace debugging
>> asynSetTraceIOMask("test-se1-1",0,2)
>> asynSetTraceMask("test-se1-1",0,9)
>> The last line is turning on ASYN_TRACEIO_DRIVER for the TCP driver. So you should see messages for every write and read operation to the device. Do you see any such I/O before it crashes? You could change the last line to:
>> to turn on all possible messages.
>> See if you get any messages before it seg faults.
>> You should also run gdb to figure out where it is crashing. Here's how to do that:
>> - Enable core dumps. With the csh this is done with
>> limit core 1000000
>> With bash it is
>> ulimit -c 1000000
>> Now run your application so it seqfaults. You will get a core file, core.XXXXX, where XXXXX is a number.
>> Now run gdb on your application with that core file:
>> gdb PATH_TO_YOUR_APPLICATION core.XXXXX
>> When you get the gdb prompt type the command
>> backtrace
>> That should show what function was executing when it crashed.
>> Here is something else to do. Load your application, but comment out the line to load the motor database. At the IOC prompt type this command
>> dbior "drvPM304",10
>> That should give you a report like the following:
>> Driver: drvPM304
>> PM304 controller 0, id: Mclennan Servo Supplies Ltd PM304 V6.17
>> Mark
- RE: Mclennan PM600 motor controller Peter Linardakis
- Mclennan PM600 motor controller Peter Linardakis
- RE: Mclennan PM600 motor controller Mark Rivers
- RE: Mclennan PM600 motor controller nick.rees
- Re: Mclennan PM600 motor controller Torsten Bögershausen
- Re: Mclennan PM600 motor controller Ron Sluiter
Re: Zero length length requests, EPICS upgrades, and cothread Matt Newville
<2013>
2025
2026
<2013>
2025
2026
