1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Binding an IOC to a single network interface
To: <[email protected]>
Date: Wed, 22 Jan 2014 14:30:29 +0000
we are looking to run a set of IOCs that bind channel access to just the loopback interface on the computer; however I saw from the 3.14 docs that EPICS_CAS_INTF_ADDR_LIST is not currently implemented in the iocCore CA Server. I had a look at the code in base/src/rsrv and the attached diff (against 3.14.12.2) seems to work for us with:
EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
EPICS_CAS_BEACON_ADDR_LIST=127.255.255.255
I was just wondering if these additions are sufficient, or have I missed something elsewhere that either needs changing too or might cause issues later on?
Freddie
Scanned by iCritical.
Index: src/rsrv/cast_server.c
--- src/rsrv/cast_server.c	(revision 774)
+++ src/rsrv/cast_server.c	(working copy)
@@ -122,6 +122,7 @@
     osiSocklen_t        recv_addr_size;
     unsigned short      port;
     osiSockIoctl_t      nchars;
+    const char*         pStr;
     if ( envGetConfigParamPtr ( &EPICS_CAS_SERVER_PORT ) ) {
         port = envGetInetPortConfigParam ( &EPICS_CAS_SERVER_PORT,
@@ -178,8 +179,19 @@
     /*  Zero the sock_addr structure */
     memset((char *)&sin, 0, sizeof(sin));
     sin.sin_family = AF_INET;
-    sin.sin_addr.s_addr = htonl(INADDR_ANY);
-    sin.sin_port = htons(port);
+    pStr = envGetConfigParamPtr ( & EPICS_CAS_INTF_ADDR_LIST );
+    if (pStr) {
+        /* this implementation only allows for specifying a single address in EPICS_CAS_INTF_ADDR_LIST */
+        status = aToIPAddr (pStr, port, &sin);
+        if (status) {
+            epicsPrintf("CAS: Error parsing %s '%s'\n", EPICS_CAS_INTF_ADDR_LIST.name, pStr);
+            sin.sin_addr.s_addr = htonl(INADDR_ANY);
+            sin.sin_port = htons(port);
+    } else {
     /* get server's Internet address */
     if( bind(IOC_cast_sock, (struct sockaddr *)&sin, sizeof (sin)) < 0){
Index: src/rsrv/caservertask.c
--- src/rsrv/caservertask.c	(revision 774)
+++ src/rsrv/caservertask.c	(working copy)
@@ -69,7 +69,7 @@
     SOCKET clientSock;
     epicsThreadId tid;
     int portChange;
+    const char* pStr;
     epicsSignalInstallSigPipeIgnore ();
     taskwdInsert ( epicsThreadGetIdSelf (), NULL, NULL );
@@ -103,8 +103,19 @@
     memset ( (void *) &serverAddr, 0, sizeof ( serverAddr ) );
     serverAddr.sin_family = AF_INET;
-    serverAddr.sin_addr.s_addr = htonl (INADDR_ANY);
-    serverAddr.sin_port = htons ( ca_server_port );
+    if (pStr) {
+        status = aToIPAddr (pStr, ca_server_port, &serverAddr);
+        if (status) {
+            serverAddr.sin_addr.s_addr = htonl(INADDR_ANY);
+            serverAddr.sin_port = htons(ca_server_port);
+    } else {
     status = bind ( IOC_sock, (struct sockaddr *) &serverAddr, sizeof ( serverAddr ) );
Re: Binding an IOC to a single network interface J. Lewis Muir
Prev: Socomec Diris Modbus support? keith.baker
Next: EPICS Collaboration Meeting 5/19 - 5/23 Institute of Modern Physics in Lanzhou, China Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Binding an IOC to a single network interface J. Lewis Muir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
