1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Binding an IOC to a single network interface
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 28 Jan 2014 16:28:28 -0600
On 1/22/14, 8:30 AM, [email protected] wrote:
> Hi,
> we are looking to run a set of IOCs that bind channel access to just
> the loopback interface on the computer; however I saw from the 3.14
> docs that EPICS_CAS_INTF_ADDR_LIST is not currently implemented in the
> iocCore CA Server. I had a look at the code in base/src/rsrv and the
> attached diff (against 3.14.12.2) seems to work for us with:
> EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
> EPICS_CAS_BEACON_ADDR_LIST=127.255.255.255
> I was just wondering if these additions are sufficient, or have I
> missed something elsewhere that either needs changing too or might
> cause issues later on?
> Thanks,
> Freddie
Hi, Andrew.
Have you had a chance to consider the patch sent by Freddie?  You seem
open to reviewing and accepting such a patch in the following Tech-Talk
post:
  http://www.aps.anl.gov/epics/tech-talk/2013/msg01493.php
I haven't looked at the patch, but the ability to specify the addresses
on which the IOC CA server listens has been a feature I've wished for
for a long time.
Thanks!
Lewis
Re: Binding an IOC to a single network interface Ralph Lange
Binding an IOC to a single network interface freddie.akeroyd
Prev: iocLog Vikram Bhagat
Next: RE: iocLog michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Binding an IOC to a single network interface freddie.akeroyd
Next: Re: Binding an IOC to a single network interface Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
