1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Binding an IOC to a single network interface
To: [email protected]
Cc: [email protected]
Date: Mon, 6 Oct 2014 15:42:32 -0500
On 1/22/14 8:30 AM, [email protected] wrote:
> Hi,
> we are looking to run a set of IOCs that bind channel access to just
> the loopback interface on the computer; however I saw from the 3.14
> docs that EPICS_CAS_INTF_ADDR_LIST is not currently implemented in the
> iocCore CA Server. I had a look at the code in base/src/rsrv and the
> attached diff (against 3.14.12.2) seems to work for us with:
> EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
> EPICS_CAS_BEACON_ADDR_LIST=127.255.255.255
Below is an adaptation of the patch for caRepeater to let it play too.
I'm unclear on whether caRepeater is considered part of CAS.  It
gets started by the IOC automatically if it's not already running,
so I considered it part of CAS.  Hence, it uses the same environment
variable.  But if it's not considered part of CAS, then I guess it
should get its own environment variable.
Andrew, I don't think you've committed Freddie's patch to the 3.15 tree,
so I'm just posting this additional patch in the hope that it could go
in with Freddie's patch when you get around to it.
Thanks!
Lewis
--- src/ca/repeater.cpp.orig	2013-12-16 15:56:27.000000000 -0600
+++ src/ca/repeater.cpp	2014-10-03 17:12:12.000000000 -0500
@@ -115,6 +115,7 @@
 		struct sockaddr_in ia;
 		struct sockaddr sa;
 	} bd;
+    const char* pStr;
     SOCKET sock = epicsSocketCreate ( AF_INET, SOCK_DGRAM, 0 );
     if ( sock == INVALID_SOCKET ) {
@@ -128,8 +129,19 @@
         memset ( (char *) &bd, 0, sizeof (bd) );
         bd.ia.sin_family = AF_INET;
-        bd.ia.sin_addr.s_addr = htonl ( INADDR_ANY );
-        bd.ia.sin_port = htons ( port );
+        pStr = envGetConfigParamPtr ( & EPICS_CAS_INTF_ADDR_LIST );
+        if (pStr) {
+            /* this implementation only allows for specifying a single address in EPICS_CAS_INTF_ADDR_LIST */
+            status = aToIPAddr ( pStr, port, &bd.ia );
+            if (status) {
+                fprintf( stderr, "CA Repeater: error parsing %s '%s'\n", EPICS_CAS_INTF_ADDR_LIST.name, pStr );
+                bd.ia.sin_addr.s_addr = htonl ( INADDR_ANY );
+                bd.ia.sin_port = htons ( port );
+        } else {
         status = bind ( sock, &bd.sa, (int) sizeof(bd) );
         if ( status < 0 ) {
             epicsSocketDestroy ( sock );
Re: Binding an IOC to a single network interface Andrew Johnson
Binding an IOC to a single network interface freddie.akeroyd
Prev: Epics Qt at APS: Formal presentation + discussion Emmanuel Mayssat
Next: Re: Binding an IOC to a single network interface Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Binding an IOC to a single network interface Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
