1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Link
To: EPICS Tech-Talk <[email protected]>
Cc: "''Ana Mellado''" <[email protected]>, [email protected]
Date: Wed, 12 Feb 2014 15:13:45 +0100
On 12.02.2014 14:28, Mark Rivers wrote:
You can do that with a Channel Access link.  The exact syntax depends on the record type, but something like the following:
record (ai, "MyLocalRecord") {
     field(INP, "MyRemoteRecord CP MS")
This will make the value of MyLocalRecord be fetched from MyRemoteRecord every time MyRemoteRecord posts a channel access monitor.
If you do not specify the type of your link, e.g.,
record (ao, "MyRecord") {
    field(OUT, "MyOtherRecord")
EPICS will determine the link type at boot time.
If the target record is found on the same host, that link will be a database link, otherwise the IOC will try to resolve it remotely (using Channel Access).
Cheers,
~Ralph
Re: Channel Access Link Kasemir, Kay
Channel Access Link Antonio Borondo
RE: Channel Access Link Mark Rivers
Prev: RE: Channel Access Link Antonio Borondo
Next: record processing time Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Channel Access Link Kasemir, Kay
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
