1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Link
To: Ralph Lange <[email protected]>
Cc: "'Ana Mellado" <[email protected]>, "[email protected]" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 12 Feb 2014 09:36:32 -0500
Hi:
Ralph's suggestion of an "OUT" link is closer to your original question how to "put" a value into another record.
In most cases, Mark's suggestion to "get" the value might be better:
If all works, the INP link shows you where the value is read.
In case of problems, "MyLocalRecord" would show an error because it cannot read its INP.
With the "OUT" link, if the IOC that holds MyRecord is stopped, MyOtherRecord would simply not be written, but you might not notice that for a long time.
Cheers
-Kay
On Feb 12, 2014, at 9:13 AM, Ralph Lange <[email protected]> wrote:
> On 12.02.2014 14:28, Mark Rivers wrote:
>> You can do that with a Channel Access link.  The exact syntax depends on the record type, but something like the following:
>> record (ai, "MyLocalRecord") {
>>     field(INP, "MyRemoteRecord CP MS")
>> This will make the value of MyLocalRecord be fetched from MyRemoteRecord every time MyRemoteRecord posts a channel access monitor.
> If you do not specify the type of your link, e.g.,
> record (ao, "MyRecord") {
>     field(OUT, "MyOtherRecord")
> EPICS will determine the link type at boot time.
> If the target record is found on the same host, that link will be a
> database link, otherwise the IOC will try to resolve it remotely (using
> Channel Access).
> Cheers,
> ~Ralph
Channel Access Link Antonio Borondo
RE: Channel Access Link Mark Rivers
Re: Channel Access Link Ralph Lange
Prev: record processing time Vishnu Patel
Next: RE: record processing time Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Link Ralph Lange
Next: record processing time Vishnu Patel
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
