1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ImageJ Plugin not working with Area Detector
Cc: Bryan Chan <[email protected]>
Date: Wed, 19 Feb 2014 19:39:46 +0000
I am getting an error message that looks like:
Feb 18, 2014 4:43:33 PM com.cosylab.epics.caj.impl.CATransport processRead
SEVERE: Received payload size (2221056) is larger than configured maximum array size (16384), disconnecting...
I am running EPICS base 3.14.12.3, areaDetector R1-9.  ImageJ is running under Ubuntu . It is version 1.47v.
The ImageJ plugin is EPICS AD Viewer.  It is connecting to the PV correctly. The program creates an image window of the correct size, but the values are zero everywhere.   If I use the “FileTIFF1” plugin I can save tiff images, and they are correct.  I have the “Image1” plugin enabled.  I am using the SimDetector IOC on the same Ubuntu machine.
I have taken a look at the documentation here:
http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html
But could not get anything to work by making changes to the jre/lib/JCALLibrary.properties file.
Any suggestions?
Thank-you,
- Yoram –
Yoram Fisher
Senior Systems Engineer
Sydor Instruments, LLC
291 Millstead Way
Rochester, New York 14624
Ph: +1.585.278.1168,   Fax: +1.585.278.1169
Email: [email protected]
web:  www.sydorinstruments.com
Re: ImageJ Plugin not working with Area Detector Kasemir, Kay
RE: ImageJ Plugin not working with Area Detector Mark Rivers
Prev: Re: Vme support in devLib for Linux Jane Richards
Next: Re: ImageJ Plugin not working with Area Detector Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing EPICS on the Raspberry Pi Torsten Bögershausen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
