1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ImageJ Plugin not working with Area Detector
To: Yoram Fisher <[email protected]>
Cc: Bryan Chan <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Feb 2014 15:06:14 -0500
There are several ways to pass those settings.
One is like this:
CA_SETTINGS="-Dcom.cosylab.epics.caj.CAJContext.addr_list=192.168.62.255 -Dcom.cosylab.epics.caj.CAJContext.auto_addr_list=false -Dcom.cosylab.epics.caj.CAJContext.max_array_bytes=100000000"
java -Xmx512m $CA_SETTINGS -jar $EPICS_EXTENSIONS/src/ImageJ/ij.jar
That way, you know for sure what's passed without having to hope that you edited the correct JCALibrary.properties.
Also note that the max array size needs to be set on both the IOC and the client.
I've been running into the case where the client complained, but the limit was actually too low on the IOC side.
-Kay
On Feb 19, 2014, at 2:39 PM, Yoram Fisher <[email protected]> wrote:
> I am getting an error message that looks like:
> Feb 18, 2014 4:43:33 PM com.cosylab.epics.caj.impl.CATransport processRead
> SEVERE: Received payload size (2221056) is larger than configured maximum array size (16384), disconnecting...
> I am running EPICS base 3.14.12.3, areaDetector R1-9.  ImageJ is running under Ubuntu . It is version 1.47v.
> The ImageJ plugin is EPICS AD Viewer.  It is connecting to the PV correctly. The program creates an image window of the correct size, but the values are zero everywhere.   If I use the “FileTIFF1” plugin I can save tiff images, and they are correct.  I have the “Image1” plugin enabled.  I am using the SimDetector IOC on the same Ubuntu machine.
> I have taken a look at the documentation here:
> http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html
> But could not get anything to work by making changes to the jre/lib/JCALLibrary.properties file.
> Any suggestions?
> Thank-you,
> - Yoram –
> Yoram Fisher
> Senior Systems Engineer
> Sydor Instruments, LLC
> 291 Millstead Way
> Rochester, New York 14624
> Ph: +1.585.278.1168,   Fax: +1.585.278.1169
> Email: [email protected]
> web:  www.sydorinstruments.com
ImageJ Plugin not working with Area Detector Yoram Fisher
Prev: ImageJ Plugin not working with Area Detector Yoram Fisher
Next: Epics/Raspberry Pi data acquisition John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: ImageJ Plugin not working with Area Detector Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
