1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ImageJ Plugin not working with Area Detector
To: "'Yoram Fisher'" <[email protected]>, "[email protected]" <[email protected]>
Cc: Bryan Chan <[email protected]>
Date: Wed, 19 Feb 2014 20:49:53 +0000
Hi Yoram,
What version of areaDetector did you get the ImageJ plugin from?
Starting with areaDetector R1-9 the ImageJ plugin gets the values of EPICS settings (EPICS_CA_MAX_ARRAY_BYTES, etc.) using environment variables, just like any  channel access client that uses the C version of the CA client library.  It does not use the JCALibrary mechanism any more.  This greatly simplified things for most people, since there is only one place that those settings need to be done for the IOC, C clients and ImageJ.
This is documented in the areaDetector release notes for R1-9:
http://cars9.uchicago.edu/software/epics/areaDetectorReleaseNotes.html
However, I just noticed that I did not update the documentation for the ImageJ viewer to reflect this change, my apologies.  I will do that this afternoon.
From: [email protected] [mailto:[email protected]] On Behalf Of Yoram Fisher
Sent: Wednesday, February 19, 2014 1:40 PM
To: [email protected]
Cc: Bryan Chan
Subject: ImageJ Plugin not working with Area Detector
I am getting an error message that looks like:
Feb 18, 2014 4:43:33 PM com.cosylab.epics.caj.impl.CATransport processRead
SEVERE: Received payload size (2221056) is larger than configured maximum array size (16384), disconnecting...
I am running EPICS base 3.14.12.3, areaDetector R1-9.  ImageJ is running under Ubuntu . It is version 1.47v.
The ImageJ plugin is EPICS AD Viewer.  It is connecting to the PV correctly. The program creates an image window of the correct size, but the values are zero everywhere.   If I use the “FileTIFF1” plugin I can save tiff images, and they are correct.  I have the “Image1” plugin enabled.  I am using the SimDetector IOC on the same Ubuntu machine.
I have taken a look at the documentation here:
http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html
But could not get anything to work by making changes to the jre/lib/JCALLibrary.properties file.
Any suggestions?
Thank-you,
- Yoram –
Yoram Fisher
Senior Systems Engineer
Sydor Instruments, LLC
291 Millstead Way
Rochester, New York 14624
Ph: +1.585.278.1168,   Fax: +1.585.278.1169
Email: [email protected]
web:  www.sydorinstruments.com
RE: ImageJ Plugin not working with Area Detector Yoram Fisher
Prev: Epics/Raspberry Pi data acquisition John Dobbins
Next: RE: ImageJ Plugin not working with Area Detector Yoram Fisher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ImageJ Plugin not working with Area Detector Kasemir, Kay
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
