1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record I/O interrupt. asyn
To: <[email protected]>
Date: Mon, 24 Feb 2014 12:01:14 +0100
On Friday, February 21, 2014 23:06:57 Mark Rivers wrote:
> For non-array records the asyn device support has a "ring buffer" that
> stores a certain number of callback values from the driver.  The
> default ring buffer size is 10.  In this case if several driver
> callbacks happen faster than the scanIORequest can complete the
> record will post monitors on all of them.  But eventually if the
> callbacks happen too fast the ring buffer will overflow and values
> will be lost.
> For array records like you are using there is no ring buffer, because
> the size could be very large and it would involve copying a large
> amount of data.
There is no need to do large amounts of copying. You simply have to
allocate a new array before filling it with new data, instead of
overwriting a previously allocated one. Then all the arrays can be
easily and safely cached/buffered/queued by reference. Indeed there is
no need to *ever* copy such an array except, maybe, when finally sending
it over the network.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Waveform record I/O interrupt. asyn Andrew Johnson
Waveform record I/O interrupt. asyn Vishnu Patel
RE: Waveform record I/O interrupt. asyn Mark Rivers
Prev: Re: epics on beaglebone Takashi OBINA
Next: Re: epics on beaglebone D Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Waveform record I/O interrupt. asyn Mark Rivers
Next: Re: Waveform record I/O interrupt. asyn Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
