1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record I/O interrupt. asyn
To: <[email protected]>
Date: Tue, 25 Feb 2014 12:26:51 +0100
On Monday, February 24, 2014 10:18:24 you wrote:
> On 02/24/2014 05:01 AM, Benjamin Franksen wrote:
> > There is no need to do large amounts of copying. You simply have to
> >  allocate a new array before filling it with new data, instead of
> > overwriting a previously allocated one. Then all the arrays can be
> >  easily and safely cached/buffered/queued by reference. Indeed
> > there is no need to *ever* copy such an array except, maybe, when
> > finally sending it over the network.
> Are you sure you're talking about features that appear in released
> versions of EPICS base? TTBOMK the support for double-buffering of
> arrays only appears in the unreleased 3.15 branch of Base, although
> I'm going to guess that Michael Davidsaver's Debian packages may have
> a back-port of that that functionality to 3.14.
Hi Andrew
I was arguing from principle, largely ignoring what's been implemented
and what not. Sorry, should have made that clearer. The point was (or
is) that I can see no reason in principle why costly copying would be
necessary to implement queued or buffered CA for array PVs. I have no
idea how deep the changes would be to actually implement this.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Waveform record I/O interrupt. asyn Vishnu Patel
Re: Waveform record I/O interrupt. asyn Benjamin Franksen
Re: Waveform record I/O interrupt. asyn Andrew Johnson
Prev: Store long strings in EPICS record. Ganesh Jangir
Next: Store long strings in EPICS record. Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform record I/O interrupt. asyn Andrew Johnson
Next: RE: Waveform record I/O interrupt. asyn Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
