1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question on Autosave
Date: Thu, 6 Mar 2014 16:09:02 +0000
I know that Autosave is generally used for automatically saving the values of a set of database records and restoring them at boot time, but I'd like to save a small set of values on command, and then be able to restore them on command.
I have found the create_triggered_set() function that I can run in the ioc startup script that assigns a database PV to trigger a save, and that seems to be a step in the right direction for what I want to do.
However, a couple of problems:
1) There seems to be no corresponding  function to assign a PV to trigger a restore.  I suppose I can get around that by using a subroutine record to call fdbrestore() when it is processed.
2) Even if I can get around issue 1), when I run create_triggered_set() in the startup script at boot time, it clobbers the existing saveset. Is there a way around this?
Perhaps I'm trying to use the wrong tool? Is there a better one for what I want to do?
Mike Westfall
PADSTE/ADE/AOT/IC/Controls
Los Alamos National Laboratory
(505) 667-3273
RE: Question on Autosave Westfall, Michael D
RE: Question on Autosave Mooney, Tim M.
Re: Question on Autosave Maren Purves
Prev: Re: CSS BEAST alarm hierarchy Igor Kriznar
Next: RE: Question on Autosave Westfall, Michael D
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer is not monitoring Pvs from another IOC Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
