1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question on Autosave
To: "Westfall, Michael D" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Mar 2014 16:24:33 +0000
Hi Mike,
Autosave 5.1 has a facility called configMenu that you should look at.  Here's a brief description from the docs
(http://www.aps.anl.gov/bcda/synApps/autosave/autoSaveRestore_R5-1.html):
"Autosave also contains a facility, called configMenu, for creating, saving, finding, restoring, and verifying IOC configurations (that is, sets of PV values). configMenu is roughly comparable to the EPICS Backup and Restore Tool, BURT, but it uses autosave files, and is driven by EPICS PVs, so it can be used manually, by software clients, and by other IOC code."
Tim
From: [email protected] [[email protected]] on behalf of Westfall, Michael D [[email protected]]
Sent: Thursday, March 06, 2014 10:09 AM
To: [email protected]
Subject: Question on Autosave
I know that Autosave is generally used for automatically saving the values of a set of database records and restoring them at boot time, but I'd like to save a small set of values on command, and then be able to restore them on command.
I have found the create_triggered_set() function that I can run in the ioc startup script that assigns a database PV to trigger a save, and that seems to be a step in the right direction for what I want to do.
However, a couple of problems:
1) There seems to be no corresponding  function to assign a PV to trigger a restore.  I suppose I can get around that by using a subroutine record to call fdbrestore() when it is processed.
2) Even if I can get around issue 1), when I run create_triggered_set() in the startup script at boot time, it clobbers the existing saveset. Is there a way around this?
Perhaps I'm trying to use the wrong tool? Is there a better one for what I want to do?
Mike Westfall
PADSTE/ADE/AOT/IC/Controls
Los Alamos National Laboratory
(505) 667-3273
Question on Autosave Westfall, Michael D
Prev: RE: Question on Autosave Westfall, Michael D
Next: Re: Question on Autosave Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Question on Autosave Maren Purves
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
