1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question on Autosave
Date: Thu, 6 Mar 2014 16:23:37 +0000
And a third problem:
The set of values I need to save and restore may span multiple IOCs.
So I'm thinking Autosave is not the right tool at all.
> I know that Autosave is generally used for automatically saving the values of
> a set of database records and restoring them at boot time, but I'd like to save
> a small set of values on command, and then be able to restore them on
> command.
> I have found the create_triggered_set() function that I can run in the ioc
> startup script that assigns a database PV to trigger a save, and that seems to
> be a step in the right direction for what I want to do.
> However, a couple of problems:
> 1) There seems to be no corresponding  function to assign a PV to trigger a
> restore.  I suppose I can get around that by using a subroutine record to call
> fdbrestore() when it is processed.
> 2) Even if I can get around issue 1), when I run create_triggered_set() in the
> startup script at boot time, it clobbers the existing saveset. Is there a way
> around this?
> Perhaps I'm trying to use the wrong tool? Is there a better one for what I
> want to do?
Re: Question on Autosave Pearson, Matthew R.
RE: Question on Autosave Mooney, Tim M.
Question on Autosave Westfall, Michael D
Prev: Question on Autosave Westfall, Michael D
Next: RE: Question on Autosave Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Question on Autosave Pearson, Matthew R.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
