1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Archiver make error
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Mar 2014 10:27:59 +0100
On 09.03.2014 15:22, zuo.jiao wrote:
I am trying to install Archiver, I downloaded the ar_20070703.tar.gz from website, there are some errors when I execute "make" in the folder of ar_20070703, how can I solve the problem? Any help will be appreciated.
Did you read the download page before you downloaded that tar file?
On the extensions page [1], the AR archiver is in the section called "Unsupported - These tools are now orphaned; the original author is no longer available or is unwilling to maintain them, they may no longer build with current versions of their dependent software packages, or they were designed for hardware that is no longer available on the open market."
On its own download page [2], it says: " This is a very old archiver, which is not recommended for adoption at new sites. Unless you're already using AR, ask tech-talk for what programs you should look at instead."
So - please do not use AR.
There are three archivers that currently in common use. Ordered by age (oldest first):
  1. The Channel Archiver, the classical option. [3] (Debian packages readily available at [4].)
  2. The CS-Studio Archiver, RDB based, which is part of CS-Studio. [5]
  3. The Archiver Appliance, a new web-service based approach. [6]
There are even more options, but I haven't heard of any those being used at multiple sites.
Which one of the three is the best for you? Depends on the specs, environment, and time scale of your project/application.
Cheers,
~Ralph
[1] http://www.aps.anl.gov/epics/extensions/
[2] http://www.aps.anl.gov/epics/extensions/ar/
[3] http://sourceforge.net/projects/epicschanarch/
[4] http://epics.nsls2.bnl.gov/debian/
[5] http://controlsystemstudio.org/
[6] http://epicsarchiverap.sourceforge.net/
EPICS Archiver make error zuo.jiao
Prev: Re: EPICS Archiver make error Jeong Han Lee
Next: Re: EPICS Archiver make error Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: A question 0f BEAST xlmzss
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
