1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks VME Ctrl-X vs. Power Cycle
To: <[email protected]>
Date: Mon, 24 Mar 2014 15:16:04 -1000
Hi Han and Rod,
Thanks for all the valuable input.
I'll add that at Gemini we use a hybrid console server + power
control unit. They're installed on nearly all our IOC's.
-Matt
http://www.wti.com/p-170-rsm-8r8-1-console-power-hybrid-ethernet.aspx
On 03/24/2014 06:44 AM, Rod Nussbaumer wrote:
> At TRIUMF, we use the control system to power cycle some VME
> crates via PLC controlled relays. This uses EPICS access control
> to regulate who can operate the relay. There is also a sequence
> of deliberate user operations required, to prevent inadvertent
> power cycling.
>    ---   rod.
> On 03/23/2014 06:29 PM, Jeong Han Lee wrote:
>> Hi Matt,
>> Only to focus the 'power-cycling or rebooting' option, here I
>> want to
>> share my options as follows:
>> * Serial server : if you can still access the CPU though
>> 'serial server'
>> at least (Digi Portserver, Moxa serial server and so on). If
>> you have
>> small number of VME crates, it is a reasonable solution.
>> However, it
>> does not work if VxWorks freezes completely.
>> * VME Crate has an Ethernet access to activate 'Reset' crate. For
>> example, Wiener supports SNMPv1/v2c so far. So, simply snmp
>> command can
>> reset the Wiener Crate.
>> * Remote Accessible Power Distribution Unit, e.g., APC AP7921, is
>> another option. It is independent upon the VME crate, and it
>> supports
>> SNMPv1/2c/3. So simply snmp command can reset a power outlet
>> which is
>> used for the VME crate.
>> When I worked at JLab, I used all three and possible methods,
>> because
>> some VME crates, installed in a experimental hall, are limited
>> to access
>> due to operation procedures/time and radiation. By simple GUI
>> interface,
>> a operator or s shift crew could execute any 'reboot' or 'reset'
>> commands easily and it worked well. However, there was one
>> concern for
>> SNMPv1/2c security issue. At that time, I only the SNMP2c
>> within one
>> subnet and hided SNMP bare commands under GUI in order to
>> reduce any
>> security issue.
>> Anyway, to resolve this issue, I asked the Wiener to support
>> SNMPv3 in
>> their VME crate controller firmware last year. And the Wiener is
>> developing "SNMPv3 support" now and may (I hope) deliver a
>> firmware that
>> supports SNMPv3, to our site this summer. We are currently
>> testing
>> response time of v1/2c/3 by using simple network
>> configurations. As you
>> know, v3 is extremely slow. Technically, ELMA has the very
>> early SNMPv3
>> (Read) support, but their support isn't good (Only Read, bad
>> MIB file
>> and so on). CAEN has no plan to support SNMPv3 yet.
>> Thanks,
>> Han
>> On 03/22/2014 06:31 AM, Matt Rippa wrote:
>>> Thanks Steve.
>>> The better coding part is always good =). But my last hang-ups
>>> were testing a new vxworks kernel and using the cross-wind
>>> debugger. Yikes! I haven't done that in years.
>>> Sounds like better negotiating with my team is in order.
>>> -Matt
>>> On 03/21/2014 10:53 AM, Hartman, Steven M. wrote:
>>>> On Mar 21, 2014, at 3:21 PM, Matt Rippa <[email protected]>
>>>> wrote:
>>>>> Can a modified reboot handler help with any of these
>>>>> occurrences?
>>>> With VxWorks, you can definitely get yourself into enough
>>>> trouble that ^X or reboot() won't be enough. A SYSRESET or
>>>> perhaps even a power cycle is needed. If you just have a
>>>> terminal shell, you are out of luck. SNS built an option for
>>>> sending a reset through the timing system to the timing
>>>> receiver board which issues a SYSRESET on the backplane
>>>> (although this is almost never used). Some VME crates have
>>>> their own network interface which can be used to send a reset
>>>> or power cycle. A network power cycler is another option. If
>>>> you don't have something like that, and the crate is far
>>>> away, you best option is careful coding.
VxWorks VME Ctrl-X vs. Power Cycle Matt Rippa
Re: VxWorks VME Ctrl-X vs. Power Cycle Hartman, Steven M.
Re: VxWorks VME Ctrl-X vs. Power Cycle Matt Rippa
Re: VxWorks VME Ctrl-X vs. Power Cycle Jeong Han Lee
Re: VxWorks VME Ctrl-X vs. Power Cycle Rod Nussbaumer
Prev: Re: VxWorks VME Ctrl-X vs. Power Cycle Rod Nussbaumer
Next: Renishaw RESOLUTE encoders Andreas Balzer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: PicoScope support? Brown, Garth
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
