I have written an EPICS application to move a sensor in a raster
pattern. This is working well. I am stuck though showing the current
raster position using an EDM X-Y graph widget. I have two ai records
which hold the current X and Y position. I thought that I should be
able to use these two scaler PVs for the X and Y graph inputs. The
graph widget displays a symbol at the correct location when the CA
connection is made. However this never gets updated even though the ai
X and Y PVs show continuously changing values. When I take the EDM
display into edit and back to run mode, it shows the symbol in the
expected place, but no further changes. It is as if the X-Y graph
widget does not accept monitors from scaler PVs. Is it possible to
achieve what I am trying to do? Any ideas?
I thought of constructing a waveform record and update it periodically
to simulate the moving raster point. This seems like much work.
Hopefully there is a simpler solution.
Thanks in advance,
Zen
- Re: EDM X-Y Graph Scott Baily
ADAndor R2-1 released Mark Rivers
Re: Problem with UInt32Digital in Asyn Wilkins, Stuart
<2014>
2025
2026
extending of visa application Yuan He
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
