1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM X-Y Graph
To: [email protected]
Date: Thu, 01 May 2014 09:24:01 -0600
On 4/15/2014 6:50 PM, Zenon Szalata wrote:
I have written an EPICS application to move a sensor in a raster
pattern. This is working well. I am stuck though showing the current
raster position using an EDM X-Y graph widget. I have two ai records
which hold the current X and Y position. I thought that I should be able
to use these two scaler PVs for the X and Y graph inputs. The graph
widget displays a symbol at the correct location when the CA connection
is made. However this never gets updated even though the ai X and Y PVs
show continuously changing values. When I take the EDM display into edit
and back to run mode, it shows the symbol in the expected place, but no
further changes. It is as if the X-Y graph widget does not accept
monitors from scaler PVs. Is it possible to achieve what I am trying to
do? Any ideas?
I thought of constructing a waveform record and update it periodically
to simulate the moving raster point. This seems like much work.
Hopefully there is a simpler solution.
This is one of the objects where going through the several screens of help is very useful. Do you have it set to "plot n pts & stop" instead of "plot last n pts"? Do you have the update setting for the "trace" set to "X or Y"? I believe the default is to only plot 2 points and then stop, and to only update the plot if both X and Y change.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
EDM X-Y Graph Zenon Szalata
Prev: Re: [CSS] freeze and lost running PV in Boy Screens Kasemir, Kay
Next: RE: cannot run medm rightly on ubuntu 13.04 Westfall, Michael D
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM X-Y Graph Zenon Szalata
Next: EPICS support plans for Solaris Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
