Hello Maurizio:
As Jeff already replied, the Channel Access server on the IOC should not be affected by the specific order in which CA clients do things.
The issue may indeed be in the driver support for your VME hardware.
Still, if you want to narrow the issue down from the CSS side, try CSS versions 3.1.x (for SNS, you can find those older ones on https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D).
CSS 3.2 uses the PVManager, 3.1 doesn't, so that would allow you to compare the behavior with two different CA client implementations.
Kay
On Apr 30, 2014, at 5:33 PM, Maurizio Montis <[email protected]> wrote:
> .. when i open the slow popup and after open the fast without closing the
> previous one..
> * i also tried to change the CSS version, using all the versions
> available from SNS site (BASIC versions from 3.2.1 to 3.2.16) but i had
> always the same situation.
- Re: [CSS] freeze and lost running PV in Boy Screens Maurizio M .
- [CSS] freeze and lost running PV in Boy Screens Maurizio Montis
RE: [CSS] freeze and lost running PV in Boy Screens Hill, Jeff
Re: EDM X-Y Graph Scott Baily
<2014>
2025
2026
<2014>
2025
2026
