1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [CSS] freeze and lost running PV in Boy Screens
To: Maurizio M. <[email protected]>, "Kasemir, Kay" <[email protected]>, "Hill, Jeff" <[email protected]>
Date: Wed, 7 May 2014 22:13:57 +0000
Hello Maurizio,
A few questions and suggestions to you:
1. You mentioned "sampling frequency", "high frequencies". I suppose you are talking about the digitizer/ADC sampling rate/speed. Right? Pay attention to the difference between this rate and the PV update rate. What is your waveform PV update rate? you can use camonitor -#1 waveformPV and watch the timestamp to calculate the update rate or use the command "caEventRate" (maybe another name?) in your $EPICS/bin/... I hope your waveform PV does not update at ~ KHz range.
2. As Steve Hartman asked, you need to check your network bandwith and the IOC load if you have big waveform data with high PV update rate.
3. As Kay pointed out, the latest CSS/BOY is based on pvManager. You can configure it to limit PV update rate to 1 Hz, which may be helpful if the data source (PV value) is really updating too fast.
4. Check out CSS message to see if it is "Out of memory". When 'Out of memory' occurs, you will see strange behavior, including frozen screen, disconnected PVs, etc.
HTH,
Yong
From: [email protected] [[email protected]] on behalf of Maurizio M. [[email protected]]
Sent: Wednesday, May 07, 2014 4:37 AM
To: Kasemir, Kay; Hill, Jeff
Cc: [email protected]
Subject: Re: [CSS] freeze and lost running PV in Boy Screens
Il 5/1/2014 2:26 PM, Kasemir, Kay ha scritto:
Hello Kay, Hello Jeff,
following Kays's suggestion i tried CSS version 3.1.X and, in according with the prediction, i had the same behavior. That's a good point!
Before starting a deep investigation in the driver support and memory order, i'm doing a couple of tests by changing the EPICS environment variable EPICS_CA_MAX_ARRAY_BYTES. This choise is consequence of trying to have understood better (i hope) the situation with the hardware:  "playing" with the sampling frequency provided by my "fast acquisition" board, i saw different behaviors on my graphical user interface:
* for high frequencies, i have the situation described in the previous mail
* for low frequencies, PVs keep connections  but sometimes there are some frozen values for a while (having both popup windows opened)
Because of driver support provides different Waveforms (in number and size) to manage and plot data acquired, i think i'm working in a situation where, in the best case, i'm borderline with the max array size. If also this my idea is wrong, i will surely take a look into the support and try to create a testbench following Jeff's suggestion.
In any case thank you very much for your help and sorry if i took too much time to answer you.
Best Regards
- Maurizio
Hello Maurizio:
As Jeff already replied, the Channel Access server on the IOC should not be affected by the specific order in which CA clients do things.
The issue may indeed be in the driver support for your VME hardware.
Still, if you want to narrow the issue down from the CSS side, try CSS versions 3.1.x (for SNS, you can find those older ones on https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D).
CSS 3.2 uses the PVManager, 3.1 doesn't, so that would allow you to compare the behavior with two different CA client implementations.
Kay
On Apr 30, 2014, at 5:33 PM, Maurizio Montis <[email protected]> wrote:
.. when i open the slow popup and after open the fast without closing the
previous one..
* i also tried to change the CSS version, using all the versions
available from SNS site (BASIC versions from 3.2.1 to 3.2.16) but i had
always the same situation.
Hello Maurizio,
A call to 'assert(ev_que->evque[ev_que->putix] == EVENTQEMPTY)'
    by thread 'CAS-client' failed in ../dbEvent.c line 701.
EPICS Release EPICS R3.14.12.4
This presumably shouldn't be caused by external circumstances such as the order of starting CA clients, or the type of CA clients.
The code involved in the IOC has been quite robust for some time now, and so my first guess is that there is some type of corruption of the data structures in the IOC. Are there some new drivers installed in this system? Does the IOC fail in other ways sometimes or is it always with this exact same assert fail? If you change the order in which driver memory is allocated during IOC startup, and or the size of memory that is allocated by drivers, does it change the outcome? Changing the order might cause the corruption to hit a different data structure in the IOC.
I also had a quick look at the logic surrounding this particular assert fail and it appears to be sound. Nevertheless, there could be something new that is occurring. If you can reproduce it in a smaller system that might help with isolating the cause (the mantra from the support department of every software company DYN).
We are quite busy now bringing the upgraded LANSCE RF systems on line. If you are feeling fairly certain that this isn't caused by layered code (probably device drivers) then let me know, and I will stare harder at the source code involved.
Jeff
~~ Maurizio Montis - Control System Engineer ~~ mobile: +39 3408428089 mail: [email protected] skype: maurizio_montis Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro V.le dell'Universita', 2 35020 LEGNARO (PD) - ITALY
RE: [CSS] freeze and lost running PV in Boy Screens Maurizio Montis
Re: [CSS] freeze and lost running PV in Boy Screens Kasemir, Kay
Re: [CSS] freeze and lost running PV in Boy Screens Maurizio M .
Prev: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Johnson, Andrew N.
Next: ADLightField Prebuilt - LightField.dll Not Found Zachary Brown
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [CSS] freeze and lost running PV in Boy Screens Hartman, Steven M.
Next: RE: [CSS] freeze and lost running PV in Boy Screens Maurizio Montis
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
