1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyEpics time stamps
To: EPICS mailing list <[email protected]>
Date: Mon, 12 May 2014 16:39:42 -0700
I’ve found the problem — the code in lib/dbr.py looks just plain wrong:
EPICS2UNIX_EPOCH = 631173600.0 - time.timezone
def make_unixtime(stamp):
    "UNIX timestamp (seconds) from Epics TimeStamp structure"
    return (EPICS2UNIX_EPOCH + stamp.secs + 1.e-6*int(1.e-3*stamp.nsec))
Problem one — that constant is wrong.  The correct value, as defined in <base>/include/epicsTime.h is: #define POSIX_TIME_AT_EPICS_EPOCH 631152000u
Problem two — what’s ‘time.timezone’ doing in there?   The unix time stamp is in UTC as is the EPICS time stamp.
I propose the following fix:
diff -u lib/dbr.py.orig lib/dbr.py
--- lib/dbr.py.orig 2014-05-12 16:37:58.000000000 -0700
+++ lib/dbr.py 2014-05-12 16:38:00.000000000 -0700
@@ -66,7 +66,7 @@
 MAX_ENUM_STRING_SIZE = 26
 MAX_ENUMS            = 16
-EPICS2UNIX_EPOCH = 631173600.0 - time.timezone
+EPICS2UNIX_EPOCH = 631152000.0
 # create_subscription mask constants
 DBE_VALUE = 1
Who’s maintaining the pyEpics stuff now?
Eric Norum
[email protected]
Re: pyEpics time stamps Mark Rivers
Re: pyEpics time stamps Matt Newville
pyEpics time stamps Eric Norum
Prev: pyEpics time stamps Eric Norum
Next: Re: pyEpics time stamps Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
