1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: writing scan data to file via CSS
To: <[email protected]>
Date: Mon, 12 May 2014 18:34:54 +0200
Hi
Again, i could use some advice how to proceed:
I have a working lab setup consisting out of a sensor and a stepper motor XY-table. Both are controlled via EPICS,
i use a sscan record for doing XY scans.
The sensor is connected via a remote pc (actually a RaspberryPi) running an epics IOC.
I have a CSS GUI to control everything. Now i want to make scans, and save the scan data (i.e. the sensor value for each X/Y-position) into a local (ASCII) file ON THE GUI PC running CSS. Not on the PC running the IOC client.
Any hint, how to implement this ?
From the docs, i understand that the natural way is to store the data on the IOC-PC.
Thanks for any suggestion/comment
Christian Pauly
Re: writing scan data to file via CSS Kasemir, Kay
Prev: Re: CSS: The difference among Javascript 、Python Script and Execute Command Kasemir, Kay
Next: Re: writing scan data to file via CSS Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector Windows 7 x64 Build Problems Zachary Brown
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
